sod it ill copy paste the bits and bats might get a bit broken english as theres thread in between but gives you an idea..
Thought id chuck it up as am stuck in the office 2001 Audi S3 210 AMK
going to try get some of it done for detailed show at end of the month but my moneys on too much work and too much eating pie to get owt done lol
Pics
some pics of the new cooler minus hardpipes..
seen as i havent been ***** to update the thread in a while thought id get back on track...
well the clutch went @ pod hence a comedy 15.9 run LMAO will i ever live that down...
so in went a stage 1 organic clutch along with a new slave cylinder, master cylinder and a new passenger front driveshaft just for good measure...
so on with some more intresting bits..
it was about time i got my **** in gear dropping the car a bit so i thought id go for a basic opener to see what difference some springs would make..
-30mm eibach vs std s3 rear
took a couple of hours but the end result (this pic is after 800miles)
as the new clutch has gone in it bites a little harder so i thought id combat the roll with a polybush an excellent mod to all g4/tt/a3
around 20mins all in to fit well worth the effort
also added a bit of silicon and carbon
a few more pics....
inside
one of my own hand made custom exhausts
pic now sus has settled a bit more and theres 15mm rear spacers im dieing for the new rims to arrive
some new bits ive been doin (not that many are intrested but helps me blog lol)
decided to get a few interior bits sorted
so added a momo top power 300mm and a richbrook knob
then took a trip to SG Styling (Unit One Long Close Works, Dolly Lane, Leeds, LS9 7TU.. 07836368971)(cheers for the tip VICK) to get some trim work done as the interior was a bit drab IMO so got him to cover the pillars and the armrest make me a new gaiter and do me engine covers.. went for alcantra as something a bit different to leather and in the timescale i gave it was a case of what was in the workshop..ill let you see the pics will be off back there soon for headlining bits of the dash doing and some new front seats
as my tints were starting to look worn and passenger side was missing from a break in as it turns out they were blue (i never noticed) and sh*te quality so out they went and in with new big up to Kar Cosmetics in Bradford (01274-572000) for persevering with the bloomin sticky stuff.. awesome job
off to belgium tomorrow but when i get back next stop will be to CAV @ Pure Detail then the bloomin lumps coming out for some forging...and maybe some new rims
gratuitous part shots
Brand new GT2871rs
Mid Way through the strip the strip down...
Haltech/Innovate Logging AFR Meter
E-Boost Digital Boost controller
Turbosmart Fuel Pressure regulator
and
new turbosmart recirc valve
even more new bits collected tonight in a hectic truck blast as theres waiting lists on everything i decided to buy second hand new stuff to get the build in motion
so picked up 4 of these pauter bad boys
and 4 of these wossners
so the bottom end should be together this weekend although ive got a stand at festival on sunday
but need to tidy up my sump due to its bashed up nature going to plate the bottom for strength and look into baffling it
best crack the ally welding gear out
