I didnt have to move anything to get mine in and out. It took about 20 minutes for me to do 1st time (i was fanny'ing about
But when I replaced the 2nd time it took about 3 minutes
The one on the right of my car was alot harder to do as the battery is in the way.
This is what I did for anyone else having trouble:
Unclip the black covers on the back of lights (I used my audi key to do this as it was much easier) which means you can take out the covers.
Have a look/feel around for the cable that is at the top of the light set, closest to the side of the car, this is your side light cable.
Give the cable a pull and it should pop out the side light aswell (connected to the end), mine didnt require any twisting/turning but I'm not sure if others are different.
Replace bulbs wiht the LEDs (check they work first before putting it back)
While looking at the front of the light (and your hand inside the bonnet), guide the led bulb back into the hole and push it until it clicks in.
Replace covers.
Its pretty simple, just have a good look and a fiddle about and you'll find its easy.
