V6 PWR - 3.0 Quattro
This might be down to the cold weather (I can always see the drop on my 3.0)...
On the other hand I usually go 1 full tank of Nitro+ then one of the regular diesel from Esso. Never noticed anything different.
Sent from my mobile...
I have gone back to ESSO. Let's see what I get in this tank
Today while cruising on motorway I got gearbox fault warning on dash with message "It's safe to drive".
First thing I did when I got home was to plug in vagcom and scan to see the fault code but there is none. What could possible be wrong?
I have been driving up and down A38 due to work these days and the best I have got is 38mpg. That is cruising in dynamic mode with 40/60/70 mph.
What's the best everyone else get. Especially 3 ltr owners.
Did a 60 mile round trip with a mixutire of 40/60/70mph in Eco mode and returned 45mpg. My daily commute is mostly 30 & 60mph commute over 15 miles. Most of the time is stuck bumper to bumper in traffic and the average is 33mpg.
On the holiday trips I get 36 doing a constant 85mph in France.
Following my dad' caravan at 65 to 70 I saw 60 plus lol. The caravan makes a huge hole in the wind resistance.
Get 34 on my commute
Reactions: Audimad
3l 245 Avant: on my summer wheels (255/35/20 OEM Pirelli) crusing at 75-80 will return 45-48 depending on the temperature;
On the winter rubber (225/55/17 Michelin Alpine 5s) doing the same, I can push it past 50.
Both done in Auto mode...
Town driving, it is mid 30s.
Should have got a BITDI far better fuel economy and power output than the single turbo 3.0 TDI's.
Changed the washers jets to new wide spray ones - should have come with them. Much better spray
5 minutes job, very easy, straight swap. Got from local TPS for £8.51 each side.
Part number: 4G0955987A (left) & 4G0955988A (right) - in case someone needs to swap
Reactions: All-rod
Starting to get gearbox malfunction but I don't feel any slippage while driving. Tried doing TCU calibration with VCDS but it get's aborted with message SAFETY REASONS.
Got price of OEM clutch from TPS £192 plus + 10 bolts = £225. Did looked at SSP performance clutches but that's over £2200 which is too expensive. It's like 10 times expensive than OEM.
Any recommendations other than OEM or SSP clutches for DSG
Code:
Thursday,15,February,2018,19:27:07:25423
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 17.8.1.0
Data version: 20171130 DS276.6
www.Ross-Tech.com
VIN: WAUZZZ4G3CN072971   License Plate:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3B 42 44 46 52 53 55 56
          5F 62 6C 72
VIN: WAUZZZ4G3CN072971   Mileage: 106733km-66320miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CDUC)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 401 F    HW: 4G0 907 401
   Component: BSR v1 OY12SV X37 0004
   Revision: 53X37---
   Coding: 0A254012052601020000
   Shop #: WSC 01286 386 08256
   ASAM Dataset: EV_ECM30TDI0114G0907401F 001004
   ROD: EV_ECM30TDI0114G0907401F.rod
   VCID: 2643A6A259844276CB-8072
2 Faults Found:
14565 - Glow Plug Control Module 1
          P06E5 00 [032] - Performance
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 104294 km
                    Date: 2018.01.29
                    Time: 11:02:29
                    Engine speed: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 12 °C
                    Intake air temperature: 12 °C
                    Ambient air pressure: 1000 mbar
                    Voltage terminal 30: 11.580 V
                    Unlearning counter according OBD: 2
                    Glow-control unit: activation voltage: 11780 mV
                    Glow_period_control_unit_ground_offset_voltage: 9960 mV
                    Glow-control unit: calculated glow voltage: 4770 mV
                    Glow_period_control_unit_energy_integrator_calculated_value: 240.5 V²s
                    Glow cycles upon reaching temperature threshold-Bit 0: 0
                    Glow cycles upon reaching temperature threshold-Bit 8: 15
                    Glow status-Bit 0: 0
                    Glow status-Bit 8: 0
                    Co EOM st Op Mode Short-Bit 0: 8
14587 - Cylinder 5 Glow Plug Circuit (Q14)
          P0675 00 [109] - Electrical Fault
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 104023 km
                    Date: 2018.01.26
                    Time: 12:10:47
                    Intake air temperature: 8 °C
                    Voltage terminal 30: 11.000 V
                    Unlearning counter according OBD: 40
                    Glow-control unit: activation voltage: 10800 mV
                    Glow_period_control_unit_ground_offset_voltage: -200 mV
                    Glow-control unit: calculated glow voltage: 11385 mV
                    Glow_period_control_unit_energy_integrator_calculated_value: 142.9 V²s
Readiness: 0000 0000
Address 02: Auto Trans (J217)       Labels:| 0B5-927-156.clb
   Part No SW: 4G1 927 156 B    HW: 0B5 927 156 F
   Component: 0B5 30 TDIRdW H10 0002
   Revision: --H10---    Serial number: 0000001340
   Coding: 000001
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_TCMDL501 A02087
   ROD: EV_TCMDL501.rod
   VCID: 2C57548A476878261D-8078
2 Faults Found:
8958 - Clutch 1
          P17CF 00 [036] - Slippage too High
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 106718 km
                    Date: 2018.02.15
                    Time: 19:01:17
                    Engine speed: 3115 /min
                    Transmission input speed: 3115 /min
                    Transmission output speed: 1007 /min
                    Engine torque: 708 Nm
                    Transmission fluid temperature: 87 °C
                    Accelerator position: 75.2 %
                    Clutch status: Kupplung 1 kann Moment übertragen
8963 - Clutch 2
          P17D0 00 [036] - Slippage too High
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 106719 km
                    Date: 2018.02.15
                    Time: 19:01:37
                    Engine speed: 1947 /min
                    Transmission input speed: 1947 /min
                    Transmission output speed: 830 /min
                    Engine torque: -40 Nm
                    Transmission fluid temperature: 90 °C
                    Accelerator position: 0.0 %
                    Clutch status: Kupplung 2 kann Moment übertragen
Address 03: ABS Brakes (J104)       Labels:. 4G0-907-379-V1.clb
   Part No SW: 4G0 907 379 F    HW: 4G0 907 379 F
   Component: ESP PREMIUM   H09 0250
   Revision: --------    Serial number: --------------
   Coding: 27A68701E465E180DB00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004017
   ROD: EV_ESPPremiAU57X_004_AU57.rod
   VCID: 34674CEA9F5820E645-8060
No fault code found.
Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
   Part No SW: 4H0 907 064 BP    HW: 4H0 907 064 BP
   Component: BCM2 2.0      H31 0333
   Revision: 00002001
   Coding: 05B82F06000000000000
   VCID: 78FFB8DACBB00486A9-802C
   Subsystem 2 - Part No SW: 4H0 905 852 C    HW: 4H0 905 852 C
   Component: J764 ELV MLB  H39 0046
   Serial number: 2311000236227013
2 Faults Found:
00447 - Function Limitation due to Over-Voltage
            001 - Upper Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 47
                    Mileage: 105273 km
                    Time Indication: 0
                    Date: 2018.02.04
                    Time: 22:13:47
01330 - Central Control Module for Central Convenience (J393)
            013 - Check DTC Memory - Intermittent
             Freeze Frame:
                    Fault Status: 00101101
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 44
                    Mileage: 106091 km
                    Time Indication: 0
                    Date: 2018.02.11
                    Time: 11:05:39
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 H    HW: 4G0 820 043 H
   Component: KLIMA 2 ZONEN H10 0062
   Serial number: 24101100040370
   Coding: 3621000820
   ASAM Dataset: EV_AirCondiBasisUDS 002037
   ROD: EV_AirCondiBasisUDS_002.rod
   VCID: 2447BCAA2FB8B066D5-8070
Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V1.clb
   Part No SW: 4H0 907 063 BF    HW: 4H0 907 063 F
   Component: BCM1 2.0      H12 0100
   Revision: 20012002    Serial number: 00000001095564
   Coding: 2600A01141348FE00581008380001D0C4F9DC30827090101000004602100
   VCID: 6DD1998EB4F2B12E4A-8038
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 110909  H35 0051
   Serial number:         110922020435
   Coding: 0045F7
   Subsystem 2 - Part No SW: 8K0 955 559     HW: 8K0 955 559   Labels: 8K0-955-559.CLB
   Component: RLS  H04 0003
   Serial number: 11726788
   Coding: 03512B
   Subsystem 3 - Part No SW: 4G0 941 531 AL    HW: 4G0 941 531 AL
   Component: E1 - LDS  H07 0044
   Serial number: 05 08 2015  00000345
   Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H02 0002
   Serial number: 252843D5000000000001
Address 10: Park/Steer Assist (J446)       Labels:| 4H0-919-475-7X2.clb
   Part No SW: 4H0 919 475 N    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0050
   Revision: 11001001    Serial number: 55901127401046
   Coding: 280106
   ASAM Dataset: EV_EPHVA18AU57X0000 002005
   ROD: EV_EPHVA18AU57X0000_002_AU57.rod
   VCID: 3D7169CEAC12E1AEBA-8068
Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H40 0040
   Revision: --------    Serial number: 003JG004YW4Q
   Coding: 30323436313330303537554A305234473053
   ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
   ROD: EV_AirbaAU10BPAAU64X_AU57.rod
   VCID: 366376E2892432F67B-8062
   Crash sensor for side airbag: driver side:
   Serial number: 3575HRB405J0SM2ME18S
   Crash sensor for side airbag: front passenger side:
   Serial number: 3585HRB40590SM2O5PE%
   Crash sensor for side airbag: rear: driver side:
   Serial number: 3515JRB40510Q8K4A16R
   Crash sensor for side airbag: rear: passenger side:
   Serial number: 3525JRB405R0Q8K47OVD
   Crash sensor for front airbag: driver side:
   Serial number: 3554VRB40510ODIIAPLA
   Crash sensor for front airbag: front passenger side:
   Serial number: 3564VRB40510ODII719F
1 Fault Found:
9438993 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 11 [137] - Short to Ground
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 100674 km
                    Date: 2017.11.22
                    Time: 15:47:52
Address 16: Steering wheel (J527)       Labels:. 4H0-953-568.clb
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20111022000145
   Coding: 000034
   VCID: 306F40FA63401CC621-8064
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Component: E221 - MFL  H08 0009
Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb
   Part No SW: 4G8 920 981 S    HW: 4G8 920 981 S
   Component: TDieGb        H79 0375
   Revision: 26181120    Serial number: 658191011591003
   Coding: 33AF08000B010600010000
   ASAM Dataset: EV_RBD4K 004040
   ROD: EV_RBD4K.rod
   VCID: 43851F36CAF6975ECC-8016
Address 19: CAN Gateway (J533)       Labels:* None
   Part No SW: 4G0 907 468 E    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0213
   Revision: --------    Serial number: 00000000280459
   Coding: 00CD077D00
   ASAM Dataset: EV_GatewUDS 001025
   ROD: EV_GatewUDS_AU57.rod
   VCID: 326B4AF2654C2ED657-8066
   Battery Monitoring Control Module:
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790807577
   Voltage stabilizer:
Address 36: Seat Mem. Drvr (J136)       Labels: None
   Part No SW: 4G8 959 760     HW: 4G8 959 760
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000015433347
   Coding: 00781B0000006001000001010101102030303232203232
   VCID: 77FDBBE6C6AE0BFEA0-8022
Address 3B: Sensor Elect. (J849)       Labels: 4G0-907-637.clb
   Part No SW: 4G0 907 637     HW: 4G0 907 637
   Component: SARA 3D       H02 0004
   Revision: --------    Serial number: EJ1BPA3200NYZ50
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 6BD5979682E6BF1E54-803E
Address 42: Door Elect, Driver (J386)       Labels: None
   Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
   Component: TSG FA        H05 0212
   Coding: 011C16205E01620002080002
   Shop #: WSC 02312 785 00200
   VCID: 428B1A32DDEC9E56C7-8016
Address 44: Steering Assist (J500)       Labels:| 4G0-909-144.clb
   Part No SW: 4G0 909 144 L    HW: 4G0 909 144 G
   Component: RCEPS         H35 0010
   Revision: 00001000    Serial number: 0006189314
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
Address 46: Central Conv. (J393)       Labels:. 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0160786197
   Coding: 011F0E2200B9048183200800000100000000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 2 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
1 Fault Found:
00532 - Supply Voltage B+
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 47
                    Mileage: 106091 km
                    Time Indication: 0
                    Date: 2018.02.11
                    Time: 11:05:39
Address 52: Door Elect, Pass. (J387)       Labels: None
   Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
   Component: TSG BF        H05 0212
   VCID: 4189153ED8EA854EDE-8014
Address 53: Parking Brake (----)       Labels: 4H0-907-801.clb
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000163118
   ASAM Dataset: EV_ParkiBrake 001022
   ROD: EV_ParkiBrake_AU57.rod
   VCID: 2A5B52924D9C6616EF-807E
Address 55: Headlight Range (J431)       Labels:| 8X0-907-357.clb
   Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
   Component: ....LWR12.... H02 0013
   Serial number: 111020-0004-085
   Coding: 1121A6101000A300
   ASAM Dataset: EV_HeadlRegulBasic 005001
   ROD: EV_HeadlRegulBasic.rod
Address 56: Radio (R)       Labels: Redir Fail!
   Part No SW: 4G0 035 056 J    HW: 4G0 035 056
   Component: Radio U STD   H52 0133
   Revision: AB001007    Serial number: 051JY0B7544128
   Coding: 010003020100000001
   VCID: 285FA89A5B905406F9-807C
Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb
   Part No SW: 4G0 035 670 Q    HW: 4G0 035 670
   Component: H-BNT-EU      H47 1034
   Revision: --------    Serial number: 428J50B7524929
   Coding: 060101000103E1EF45008F3E00000003000001000000000000
   VCID: 316945FE684A15CE2E-8064
   Subsystem 1 - Part No: 8R0 060 884 ED
   Component: EUR 2017  2402
   Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDB1301U7V0
   Subsystem 3 - Part No SW: 4G2 919 610 C    HW: 4G2 919 610 A
   Component: E380 BDT C7  H08 0204
   Serial number: 90349KJK00025
   Subsystem 4 - Part No: 8R0 060 961 B
   Component: CD-Database  3371
1 Fault Found:
03623 - Invalid Secruity/Release Code
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 192
                    Mileage: 102354 km
                    Time Indication: 0
                    Date: 2018.01.08
                    Time: 23:26:44
             Freeze Frame:
                    Hex Value: 0x0004
                    Hex Value: 0x000B
                    Count: 6
Address 62: Door, Rear Left (J388)       Labels: None
   Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
   Component: TSG HL        H04 0212
   Coding: 010814204001620002080002
   VCID: 44871C2AC7F89066F5-8010
Address 6C: Back-up Cam. (J928)       Labels:* None
   Part No SW: 4H0 907 428     HW: 7P6 907 441 D
   Component: TopView       H05 0090
   Revision: 11001001    Serial number: 82330JF0013479
   Coding: 0200000001000100000102000000
   Shop #: WSC 02314 785 00200
   ASAM Dataset: EV_CamerSysteTopViewAUDI 003019
   ROD: EV_CamerSysteTopViewAUDI_003.rod
   VCID: 6ADB92928D1CA6162F-803E
Address 72: Door, Rear Right (J389)       Labels: None
   Component: TSG HR        H04 0212
End-------------------------(Elapsed Time: 04:52)--------------------------
Windscreen got chipped the other day and it was right in front of my eye line. Got it replaced today by autoglass
Getting annoyed of seeing airbag light ON all the time due to passenger seat belt tensioner. Had enough and bite the bullet for replacement part from local TPS for £258.79 + VAT
As per advise of Audi technician I bought new seat belt for £310.55 to get rid of air bag light on dash. After replacing the belt, airbag light is still on meaning original belt was never faulty.
Now how can I get refund as I bought part direct from tps and replaced the part myself.
Recommend brake discs other than OEM please.
Anyone heard of Kinetix discs and Mintex brake pads? There are few on bay reasonably priced.
Last night had Gearbox malfunciton warning on dash again. Did scan and it came up with error 8030 - Cooling Oil Valve. P179D - Electrical Malfunction. The heating system wasn't working on full potential either. Couldn't increase the fan speed from half either.
In morning, drove to work which is 40 miles and all seems ok. Any idea's what it could be.
