Hi all
So I got a hollow knock on the front nearside. Can't figure out where it's coming from.
Sounds like loose knock like arb hitting the subframe. So would seem easy to spot...
Had it on a ramp and everything is solid and looking spot on. Had wheel off can see anything obvious. It seems to disappear after it's been Jacked up but slowly comes back.
Only way to replicate it with the car not moving is on full left lock and bouncing the car on that corner, which is clearly audible Behind the wheel.
But for such a loose knock you'd think you'd be able to feel some play somewhere but nothing. It doesn't knock with every bump in the road either.
Cant figure it out. Anyone had anything similar and had a solution.
It's 2011 2.0tdi. Any help with this would be greatly appreciated. I'm pretty clued up so tried most the obvious things. But I'm new to tt's
