been having a few problems with my audi a3 over the weekend .
On friday evening went out to start the car and the dash lights were all on and no mileage reading or time showing on the clocks .
The engine starts ok but will run a bit lumpy for a while then goes back to normal.
I've scanned the car with vcds
The problem seems to be with suply b+ as this shows up on the radio and in the instruments can anyone point me in the correct direction to find this fault?
thanks Neiller
Monday,27,March,2017,19:41:47:05031
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
www.Ross-Tech.com
VIN: License Plate:
Mileage: 119130km-74023mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 61
VIN: WAUZZZ8P8AA105851 Mileage: 119130km-74023miles
01-Engine -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 1010
Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 M HW: 03L 906 023 L
Component: 1,6l R4 CR td H23 8790
Revision: --H23--- Serial number: AUX7Z0IDFN4066
Coding: 00114014030501080000
Shop #: WSC 06314 000 00000
ASAM Dataset: EV_ECM16TDI02013L906023M 003009
ROD: N/A
VCID: 306888EF6B30F4BEED-8064
No ASAM data for: "EV_ECM16TDI02013L906023M" (VW36 *)
1 Fault Found:
10119 - ROD - Unknown Error Code
- 00 [096]
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 117840 km
Date: 2017.01.19
Time: 15:29:48
Readiness: 1000 0000
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 13422012092200FFC81304E9901A0091380800
VCID: 7AFC6AC7F5CCFEEE13-802E
No fault code found.
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect. (J519) Labels: 8P0-907-063.clb
Part No SW: 8P0 907 063 A HW: 8P0 907 063 A
Component: BCM PQ35 M 105 0575
Revision: 00105 AK
Coding: 0E000A2FB005F000202041E00000014C431A23AA004DC122E4008F800041
VCID: 326C82E76D3CC6AE9B-8066
Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00DD13
Subsystem 2 - Part No: 8P0 951 177
Component: Innenraumuebe H04 0020
Subsystem 3 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 4 - Part No: 1K0 907 719 C
Component: Neigungssenso 005 0003
2 Faults Found:
00332 - Control Circuit for Tank Flap
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 4
Fault Frequency: 1
Reset counter: 89
Mileage: 113790 km
Time Indication: 0
Date: 2016.08.03
Time: 01:27:57
Freeze Frame:
Term 15 Off
Voltage: 12.15 V
OFF
ON
Term 50 Off
OFF
OFF
01598 - Drive Battery Voltage
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118007 km
Time Indication: 0
Date: 2017.02.03
Time: 17:56:14
Freeze Frame:
Term 15 On
Voltage: 13.90 V
ON
ON
Term 50 On
OFF
ON
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 P HW: 8P0 959 655 P
Component: Airbag AU1042 H06 0160
Revision: -------- Serial number: 003FB004LH4W
Coding: 303142413039303030384A55305238503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 4FAAEB1316CE8B4694-801A
Crash sensor for side airbag; driver side:
Serial number: 34928RB4000052EDAEA7
Crash sensor for side airbag; front passenger side:
Serial number: 35028RB40000530B1ECK
Crash sensor for side airbag; rear; driver side:
Serial number: 35128RB4000052EDB56V
Crash sensor for side airbag; rear; passenger side:
Serial number: 35228RB40000530B3075
Crash sensor for front airbag; driver side:
Serial number: 35547RB4000052AA2FF$
Crash sensor for front airbag; front passenger side:
Serial number: 35647RB4000052AA2A7R
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 DB HW: 1K0 953 549 DB
Component: J0527 037 0070
Coding: 0000002
VCID: 75E679FB1CD291967E-8020
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 952 A HW: 8P0 920 952 A
Component: KOMBIINSTR. VDO H03 0980
Revision: D0H03005 Serial number: 124DI005000569
Coding: 0004428
Shop #: WSC 00664 210 87559
VCID: 346084FF5728C89E89-8060
2 Faults Found:
00447 - Function Limitation due to Over-Voltage
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 4
Fault Frequency: 4
Reset counter: 252
Mileage: 119120 km
Time Indication: 0
Date: 2017.03.24
Time: 02:59:02
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 252
Mileage: 119120 km
Time Indication: 0
Date: 2017.03.24
Time: 02:59:42
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AF HW: 1K0 907 951
Component: J533 Gateway H17 0231
Revision: H17 Serial number: 1321J09C0400B3
Coding: E9801F06000202040101
VCID: 6BD25F834A96576698-803E
1 Fault Found:
03406 - Control Module for Battery Monitoring
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 243
Mileage: 118700 km
Time Indication: 0
Date: 2017.03.07
Time: 16:59:46
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H03005 Serial number: AUX7Z0IDFN4066
Shop #: WSC 00000 000 00000
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 N HW: 8P0 959 801 N
Component: Tuer-SG H04 0100
Coding: 0131636
VCID: 4684CE3731B44A0E27-8012
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 232 3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 316E8DEBA83AFDB6E2-8064
1 Fault Found:
00750 - Warning Lamp
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
Voltage: 11.38 V
DD
Temperature: 16.0°C
RPM: 0 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 N HW: 8P0 959 802 N
Coding: 0131636
VCID: 479AC33336BE5306DC-8012
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 152 E HW: 8P0 035 152 E
Component: R Chorus2+ H03 0280
Revision: 00H03000 Serial number: AUZ1Z2I5630395
Coding: 0000021
VCID: 2D56919BB4029956C6-8078
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 226
Mileage: 117763 km
Time Indication: 0
Date: 2017.01.03
Time: 17:24:04
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 1K0 907 534 HW: 1K0 907 951
Component: Batt.regelung H17 0231
Revision: -------- Serial number: 1321J09C0400B3
Coding: 0303085A
VCID: 68D8208F9B607C7EF5-803C
Subsystem 1 - Part No SW: 1K0 915 181 C HW: 1K0 915 181 A
Component: J367-BDM H07 0125
2 Faults Found:
02252 - Generator
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 243
Mileage: 118700 km
Time Indication: 0
Date: 2017.03.07
Time: 16:59:51
00458 - Control Module for Battery Monitoring (J367)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 243
Mileage: 118700 km
Time Indication: 0
Date: 2017.03.07
Time: 16:59:51
End-------------------------(Elapsed Time: 02:15)--------------------------
thanks Neiller
www.Ross-Tech.com
VIN: License Plate:
ROD: N/A
1 Fault Found:
- 00 [096]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 117840 km
Date: 2017.01.19
Time: 15:29:48
Revision: 00H30001
Cannot be reached
Revision: 00105 AK
Coding: 00DD13
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 89
Mileage: 113790 km
Time Indication: 0
Date: 2016.08.03
Time: 01:27:57
Freeze Frame:
Term 15 Off
Voltage: 12.15 V
OFF
ON
Term 50 Off
OFF
OFF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 118007 km
Time Indication: 0
Date: 2017.02.03
Time: 17:56:14
Freeze Frame:
Term 15 On
Voltage: 13.90 V
ON
ON
Term 50 On
OFF
ON
Coding: 0000002
Coding: 0004428
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 252
Mileage: 119120 km
Time Indication: 0
Date: 2017.03.24
Time: 02:59:02
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 252
Mileage: 119120 km
Time Indication: 0
Date: 2017.03.24
Time: 02:59:42
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 243
Mileage: 118700 km
Time Indication: 0
Date: 2017.03.07
Time: 16:59:46
Coding: 0131636
Revision: 00H17000
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
Voltage: 11.38 V
DD
Temperature: 16.0°C
RPM: 0 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
Coding: 0131636
Coding: 0000021
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 226
Mileage: 117763 km
Time Indication: 0
Date: 2017.01.03
Time: 17:24:04
Coding: 0303085A
2 Faults Found:
02252 - Generator
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 243
Mileage: 118700 km
Time Indication: 0
Date: 2017.03.07
Time: 16:59:51
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 243
Mileage: 118700 km
Time Indication: 0
Date: 2017.03.07
Time: 16:59:51
