Shiz94
- Joined
- Mar 7, 2017
- Messages
- 106
- Reaction score
- 17
- Points
- 18
Sunday,24,September,2017,11:53:47:10909
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WAUZZZ8P9AB023038 License Plate: GY10 EEP
Mileage: 160140km-99506mi Repair Order:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 47 52 56 61 62 72 77
VIN: WAUZZZ8P9AB023038 Mileage: 160140km-99506miles
01-Engine -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 AB HW: 03L 906 018 AG
Component: R4 2.0l TDI H20 9979
Revision: 41H20--- Serial number: AUX7Z0J1FNM09I
Coding: 00190012040501080000
Shop #: WSC 42771 002 1048576
ASAM Dataset: EV_ECM20TDI01103L906018AB 003012
ROD: EV_ECM20TDI01103L906018AB.rod
VCID: 6A8C306A3CFD4087E5E-803E
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 13424012092400FDC80B02E790210092390800
Shop #: WSC 00046 412 00000
VCID: 7AAC002A4CDDF00715E-802E
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BM HW: 8P0 820 043 BM
Component: KlimavollautomatH09 0150
Revision: 000602 Serial number: 8P0820043BM
Shop #: WSC 00000 000 00000
VCID: 78A81A227ED1E21763A-802C
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 A HW: 8P0 907 063 A
Component: BCM PQ35 M 105 0575
Revision: 00105 AK
Coding: 0E000A2FB005F0C0207041E00000815C431B29AA015DC12AE4088F800041
VCID: 323CE80AD42DC8479DE-8066
Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00DD13
Subsystem 2 - Part No: 8P0 951 177
Component: Innenraumuebe H04 0020
Subsystem 3 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 4 - Part No: 1K0 907 719 C
Component: Neigungssenso 005 0003
Address 10: Park/Steer Assist (J446) Labels:. 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 G HW: 8P0 919 475
Component: PARKHILFE 4K H06 0120
Revision: 11001001 Serial number: 93631005410794
Coding: 000003
VCID: 42DCB8CA648D78C70DE-8016
Address 15: Airbags (J234) Labels:| 8P0-959-655-10.clb
Part No SW: 8P0 959 655 P HW: 8P0 959 655 P
Component: Airbag AU1042 H06 0160
Revision: -------- Serial number: 003FB005PCN8
Coding: 30314238303830303037554A305238503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 4FFA81FEA75F85AF920-801A
Crash sensor for side airbag: driver side:
Serial number: 3572DRB40000ABC4F094
Crash sensor for side airbag: front passenger side:
Serial number: 3582DRB40000A904915P
Crash sensor for side airbag: rear: driver side:
Serial number: 35128RB400005610CC9K
Crash sensor for side airbag: rear: passenger side:
Serial number: 35228RB4000055CDDBE6
Crash sensor for front airbag: driver side:
Serial number: 35547RB40000571EFAA%
Crash sensor for front airbag: front passenger side:
Serial number: 35647RB40000571F041E
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0004012
Shop #: WSC 00011 219 00000
VCID: 46D4A4DA44A544E7216-8012
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0100
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 J HW: 8P0 920 982 J
Component: KOMBIINSTR. VDO H03 0990
Revision: D0H03005 Serial number: 2241J005019884
Coding: 0004428
Shop #: WSC 40647 001 104857
VCID: 40D8B2C266816AD71BA-8014
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AF HW: 1K0 907 951
Component: J533 Gateway H17 0233
Revision: H17 Serial number: 1521J10215042A
Coding: E9A07F06100602042103
VCID: 6B82356E3F87598F9E8-803E
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H03005 Serial number: AUX7Z0J1FNM09I
Shop #: WSC 40647 001 1048576
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8P0 959 801 M HW: 8P0 959 801 M
Component: Tuer-SG H04 0100
Coding: 0135860
VCID: 45D6A3D679A34FFF28C-8010
2 Faults Found:
01552 - Motor for Central Locking; Drivers Door (V56); Lock
012 - Electrical Fault in Circuit - Intermittent
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal - Intermittent
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 232 3001
Revision: 00H17000
Shop #: WSC 00046 000 90108
VCID: 313EE706DD2BF35FE44-8064
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 E HW: 8P4 035 382 E
Component: AB2 SUBWOOFERBOXH07 0180
Revision: 00006 Serial number: 92158067884406
VCID: 3634D41A3445D467B16-8062
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
Part No SW: 8P0 959 802 M HW: 8P0 959 802 M
Coding: 0135860
2 Faults Found:
00097 - Front Passengers Central Locking (Safe) Motor (V162)
00936 - Electric Window Switch in Front Passenger Door (E107).
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 S HW: 8P0 035 186 S
Component: R Concert2+ H03 0280
Revision: 00H03000 Serial number: AUZ1Z3K6018081
Coding: 0710111
VCID: 42DCB8CA688D78C70DE-8016
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 1K0 907 534 HW: 1K0 907 951
Component: Batt.regelung H17 0233
Revision: -------- Serial number: 1521J10215042A
Coding: 0303085A
VCID: 68884A6222717297F3A-803C
Subsystem 1 - Part No SW: 1K0 915 181 E HW: 1K0 915 181 A
Component: J367-BDM H07 0140
Serial number: 00000000005651045629
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
Component: Tuer-SG H04 0050
Coding: 0131216
Shop #: WSC 00046 412 1012544
1 Fault Found:
00098 - Rear Left Central Locking (Safe) Motor (V163)
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Coding: 0131216
VCID: 43D2BDCE779771CF068-8016
1 Fault Found:
00099 - Rear Right Central Locking (Safe) Motor (V164)
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 AA HW: 8P0 862 335 S
Component: FSE_256x BT H38 0600
Revision: 00000000 Serial number: 00000005174830
Coding: 0001222
VCID: 75B6131669C39F7F78C-8020
End----------(Elapsed Time: 01:29, VBatt start/end: 12.3V/12.3V)-----------
As per title
www.Ross-Tech.com
Revision: 00H30001
Revision: 00105 AK
Coding: 00DD13
Coding: 000003
Coding: 0004012
Coding: 0004428
Coding: 0135860
2 Faults Found:
Revision: 00H17000
Coding: 0135860
2 Faults Found:
Coding: 0710111
Coding: 0303085A
Coding: 0131216
1 Fault Found:
Coding: 0131216
1 Fault Found:
Coding: 0001222
As per title
