Patrico777
- Joined
- Sep 11, 2017
- Messages
- 286
- Reaction score
- 9
- Points
- 18
Take it back where the cam belt was changed I would suggest as it could’ve something wrong with that by the coding errors shown.
The coil lights relate to the glow plugs - though I wouldn’t of thought they would be at fault because they are not really needed yet as it’s not cold enough.
Be mindful of any potential injector faults. Also if it relates to issues with the injectors, EGR valve, DPF remember to contact the Audi emisissions help line which is in relation to having the crappy emissions recall done
Yes I do have breakdown, I hope its not bad I oaid 9,5k for the car and im skinny atm got 3 months warranty for the car but If its injectors I dont think they pay that much i think warranty give 2k per claim max? If so i take the car back if I can I had it 15daysHave you got break down cover? If so might be worth giving a call out to get a fault code
I will go and check myself soon for anything unplugged etc, spoke to showroom where I bought the car from he said to me not to be worried that I need to go back to audi as they could done something not plug something in or something and so if audi could give him call after diagnose at least they are helpful and not letting me on my own I hope it gets sorted on Monday I hope I can drive as I need to get to workIt’s difficult to say really - could be a loose connection etc. Need to see what the garage says.
The clicking noise - people have reported rough running post fix - I don’t want to worry you though, have a look at the FB group I mentioned
All lights are gonne car back to normal! Im so confused will update u on monday what audi saysIf it is EGR failure make you can’t the VW emissions team and look into trust building measures introduced
Ok its egr valve getting it changed around £700 at audi the showroom will pay it for meIf it is EGR failure make you can’t the VW emissions team and look into trust building measures introduced
Ok it came back the light so egr need changing price is £729, he said he will contact his boss, so will see tomorrow but I think they gonna change it no optionfor themGood so they should pay it’s the emissions fix that broke it in the first place... however it may not last that long after....
What does it mean they will change it free ?https://m.audi.co.uk/about-audi/diesel-info.html
Please read that before you end up getting charged for anything
How because of the recall? They damage egrs? What should I tell them?Yes they should be doing it for free - DONT PAY FOR IT!!!
Ok Im going to try that, what research regarding the recall ?Contact Audi (not the dealer Audi UK) by phone ask to speak to the emissions team, explain that the car has had the emissions recall completed and that EGR has failed.
Try and do a little bit of research on it first.
Deffinetly! So pleased ! Thanks mate for help!!!Good result
But what does this code mean might be another problem ? P0013-1b camshaft actuator ? From finding its fault with cambelt ? Maybe they done somethingGood result
