JohnDuh
- Joined
- Aug 18, 2016
- Messages
- 160
- Reaction score
- 26
- Points
- 28
I'm in westende along the coast.where are you from in belgium? maybe i can help...
Sent from a green cloud on planet Procrastination
The vacuum has been measured to be OK.
Yes, measured at one of the many mani connections.Is that intake mani vacuum? Not sure how likely this is, but false air can be drawn in under vacuum. I know my car had several split pipes in the brake servo vacuum supply, might be worth checking out.
A bit more than that, I have no power and massive missfires at higher rpm, like in not driveable at all.so you have no boost? and a rough idle? what have you already changed/tested/checked on the car?
try to do a emission test, so you know its over or underfueling
Unfortunately not yet. Bought it new, but I've read that's not a guarantee.Is the maf confirmed to be working properly, i.e. on another car?
Will have a look, if Ill have a dig around there. Am I right when looking at block 31 for lambda?forget the maf, won't be the problem. you need to find out wether it's running to rich or to low. it will give you a lead to what may be the fault.
bad idle suggest to much fuel. check the egt sensor for bad connection, oxidated connectors.
the throttle valve isn't opening or closing according to engine commands
Could you confirm this by taking the hose off the TB and visually checking the valve movement? I'm not sure if this would work without the engine running, since mine is cable-operated... (for now)
i did a search and the only thing blocking seems to be some brake lines,right?There have been a few LHD owners to fit them, you'll have to give it a search and maybe contact them. It's definitely worth the effort to get one fitted tho.
I'm wondering if the 100% silicone may be a better option than the billet one due to more flex. Just a thought
Im thinking i could get away with adding some protctor between them.
Should be, I didn't have enough time to rebuild everything.So is she all fixed now?
Did you end up damaging anything in your engine with the low oil pressure?Had the dreaded low oil pressure problem myself,engine rattling up top.
Changed oil pump,cleaned pick up pipe and replaced some PCV pipes & hockey puck...sorted out the problem but did starve my turbo at the same time so that had to be replaced but may have been on the way out as 135000 miles...
http://www.audi-sport.net/xf/thread...ad-my-baby-is-home.261997/page-8#post-2935127
That would be good news. ;-)can be the timing chain tensionor you are hearing
All of them. The inlet cam is driven by oneThat would be good news. ;-)
Do all engines have that chain, or is it only vvt heads?
Sent from my ONE A2003 using Tapatalk
mhhh ... the rattling in mine wasn't horrible, just some mechanical clicking over normal engine sound. Hopefully the eninge will be OK.Just the turbo on mine,it died on the second test run after changing the oil pump,etc.
When I had the problem it was a seriously load rattling coming from the top of the engine,inside the cam cover,I would say.
I feared the worst from the noise but rest of the engine was fine.
Thats what I used, except mine had a longer shaft and a handle on the end. Could just make the awkward angle and the bolt came undone just before the crazy amount of torque snapped the tool in half...I found these helpful when removing the sump...
