Turbo hiss (strange one )
Turbo-mick
Hi guys
Not been on for a few years but struggling with the new motor. I've had a month or 2
Basically the turbo hisses like a air leak and has a slight police siren when dropping back down . But the strange thing about it is, it only happens when I put the throttle down about a cm around 1800rpm to 2000rpm. Once I've passed the 2000rpm the hiss has gone. it's not a normal turbo spool as it's too loud for a standard car.
So basically I removed and fit new seals on all the pipes and even fit a brand new turbo. Egr delete. but it's still the same.
So if am just cruising with the throttle only just applied it hisses. Soon as I floor it or even apply the throttle 2cm it's gone
Bkd 140
Has any body else had same issues
I had exactly the same issue on the same engine. Sold it without ever getting to the bottom of it, hopefully someone here will have a solution.
Hi guys
Bkd 140
I have an A3 with BKD 140 engine, never noticed a hiss but the turbo does sound like a police car and its noisey as hell so that would drown out any small hiss haha, been like it for 4 years and still pulls as well now as it did when i bought the car.
Sent from my SM-G935F using Tapatalk
I have this issue when it is on low revs/low speeds and it seems to dissapear when you're going at a faster pace. The issue seemed to arise after a remap. Right pain when going through a village but as the others have said it seems to pull fine.
Cheers lads. I've got a mate to hold the revs at 2k rpm and the hiss noise is there like when driving. Sounds to be coming around the intake flexi from the maf sensor. If I put my hand over it the hiss goes quite. Removed and pressurised it and no leaks so fitted it back and and the same again. Any chance you could try the same with yours. Maybe a bar on the throttle to hold at 2000 rpm while u have a listen
I'll have a look at mine when I get a chance for u mate may be Saturday though, the only day where I'm not mega busy plus fitting my new starter motor that day anyway so will have a look.
Thanks mate.
Think am going to order the upgraded silicone one from darkside
Any look mate
I checked mate I have no his from i can hear, sorry, like I said though my turbo has been loud n sounds like a siren since I bought the car 4 years ago n the cars fine n drives and pull very well so I don't think u have anything to worry about tbh
Sorry to resurrect an old thread. Did anyone find a way to cure the turbo hiss/siren noise when at low revs?
Mine has been hissing and sounding like a police siren for the last 5-6 years. Remapped also.
Pulls well and no errors.
Does not bother me anymore but people in the street will sometimes turn their heads :busted cop:
I know what you mean. Its worse when going along slowly but as you said remap is still pull well with no errors
