DeanoC's S Line
DeanoC
Well-Known Member
I thought I'd do a thread to keep all the tweaks in the same place.
This is my C7 S line. My last car was a B8.5 RS4 so it's taking some getting used to a 2.0 TDI multitronic!
Sent from my SM-G935F using Tapatalk
Reactions: Bristle Hound
Day 1 mod was some LEDS and coding:
Reactions: AL_B
Next i thought i better check the engine was healthy post dieselgate tweaks:
Time to lose that ****** grill that doesn't match the front or rear honeycomb:
Next was to sort the crappy light output. You're looking at tuned shutters and RV shields, clear lenses, Osram CBI's and 50w morimoto ballasts:
Reactions: AL_B
Quick rusty brake and bell fix up in the audi ceramic brake grey:
He's at it again!
Reactions: Bristle Hound and DeanoC
How much do all these lights cost then? After seeing the difference on your RS4, it's a must isn't it?
Reactions: DeanoC
Absolute no brainer mate.
The other night in the C7 i had the full beam on for 20 mins by mistake and it was worse than dipped on the RS. The cost is in the labour so if you are brave you could do lenses, bulbs, ballasts and shutter mods for about £400. If you get Trups to do them then double it or more as you will likely get other bits done at the same time
Reactions: Thundercliffe81
Flipping eck. Why so expensive?
It's not really. Ballasts are less than what audi would charge for OEM, same with bulbs, and lenses are hard to make. £100 for some lenses for your car, youd pay double that down the opticians for your eyes
Thats s fair point when you put it like that. Yours got Matrix?
No just plain old non adaptive bi-xenons. LED tech is still not all that, my RS was well ahead of my LED BMW and SEAT after the mods. I'm taking some 'after' photos tonight after i have aligned them
Light output. Same f5 1/10 settings at the same time so no idea what is with the sky.
Reactions: AL_B
Decided grey looked gash:
Reactions: Bristle Hound and Thundercliffe81
Asides from the cost in this, how hard is it to do?
Swapping out the ballasts and bulbs is 10 mins and no difficulty once you have tue car up and bumper off.
Titanium rings to match the rotors and sline trim. I plan to add a titanium splitter to the front once i find a decent one.
Reactions: Wifeb4Life, Thundercliffe81 and Radford212
Couple of little decals to finish the brakes off
Messing about with badges. Big, little or none....?
The black brakes with sline decals go well. I'd always say debadged but it is Personal preference
Reactions: DeanoC
Well I (and the mrs) finally got around to sorting the shocking paintwork out.
Before:
After:
Reactions: Rhyso and Bristle Hound
Very nice work, looks so much better. Mine is no where near as scratched as yours was to start with but definetly wish you could come and do mine :D
Bit further with the dechrome. Window, dash and door trim done
Reactions: Aly, Thundercliffe81 and Rhyso
Did you have the trim wrapped or did you get hold of the OEM trim?
It's wrapped. I would do the trim if i could find it.
Cool. How much did it cost if you don't mind me asking? :)
Couple of hundred quid for proper 3m vinyl.
Reactions: Thundercliffe81 and Rhyso
Little one today but one I've wanted to crack for ages.
Conscious winter was coming i wanted a deep boot liner but i wanted to retain the load restraining hooks. I finally found a liner that allows you to do it but stupidly the positions meant the hooks near the tailgate where on the removal section and therefore not locked down. So i swaped the rails around
Reactions: Rhyso, SPek9 and Thundercliffe81
I put the facelift fan type washers on. So much better!
Reactions: Rhyso and Thundercliffe81
Great write up.
I have just got the same load liner. What do you have to do to the rails to make it work?
Great write up.
Thanks. Basically unbolt them, swap the end caps around, mark the fixing points and drill new holes.
Sent from my Pixel 2 using Tapatalk
