Hi all
I've fitted an Rns-e unit in my b6 a4 avant and it works great, I even got a tv tuner adapter module so that I can use an external av source (in this case a dvd player thats now resides on the glove box) however the unit was originally taken from an a3 and as such will have its audio profiles set up for an a3, I have vcds so in theory I should be to change the settings in adaptation however the unit does not comunicate with vcds at all, I'm sure I read somewhere that in the b6 a4 there are wires that need swapped going to the head unit to allow for correct coms, can anyone confirm this and if so which wires do I need to swap,
Regards and thanks,
Mark
Regards and thanks,
Mark
