Oli what you think about this dyno what I miss
http://www.vwroc.com/forums/topic/1...rmation-thread/?do=findComment&comment=322681
Guys I have for sale brend new newer used jb4 ver 1 upgrade kit! 100£ shipped. More info PM
Anyone know when is the firmware update coming? I heard end of April
Sent from my HTC 10
I don't think there is anything in that, power seems high but that's easily manipulated or just down to the dyno.Oli what you think about this dyno what I miss
Also without any mods to cool the air to and from the turbo on a dyno our cars are cooking themselves. On the road in the UK the top end should make another 10hp easily. A little fan isn't anything like the airflow at the top end of 3rd or 4th and so on. My IAT is fine on logging on the road and then on the dyno it was 140f in a 70f room by the end of the first run. On the road it would have been 90f and would have run more timing
Sent from my SM-G935F using Tapatalk
My run that made 328whp was 150f so yes with an updated intercooler I would have made more power on the dyno but on a normal day in the UK I'm sure it would be nearly the same on the road140f is HOT...
Almost certainly would have been even better figures at 90.
I got upgrade kit ver 1 from jb1 to jb4Does anyone have a JB4 for sale
Yes it willWill running a decat/sports cat downpipe allow one to run higher boost ?
So that it raises the boost in 1st, 2nd and 3rd and runs the same boost pressures all year around. This of course means settings in the winter might be too aggressive in the summer heat.Why do people use absolute instead of additive boost values, and one thing I've noticed is the boost levels increase per gear, anyone else notice that ?
Just want to get an opinion on this log, additive peak 6.5psi. Starting from gear 1 to redline gear 4
The post gear change 'overshoot boost' in 4th is quite high, 27 psi.
Other than that it looks very good.
A software update including gear change boost adaption is coming soon though. End of April according to latest update from George.
I pryed it with screwdriver - it opens up
U can connect to android if u got jb4 apo or u can connect directly on laptop as wellThanks! Got it opened and installed the cable just now! So I can use an USB adapter and connect an OTG USB cable to connect to Android right?
Sent from my HTC 10 using Tapatalk
Nothing Bad just going for a proper map, as I have already mapped the gearbox so I might aswell do the engine
Ran my first additive map settings today as suggested by George. A massive difference in power delivery, very linear and any jerkiness that was there previously has now gone.
I'm running 98RON with the following mods.
BMS Intake with larger turbo inlet elbow
BMS turbo muffler delete
GFB Diverter valve +
Also managed to break the 4 second barrier for the first time, so I am very happy
Map 6 is better than map 1 for smoothness and your clutch if it is set up correctly. You just don't want too much boost before 3.5k to save your clutch. Bringing the torque in later can move the power band up as wellI've been reading a lot on different forums about JB4 and I can't seem to find a definite answer to below question:
If I'm running Map 1 (and not map 6) am I still able to set a max boost in 1st of e.g. 2 psi to put less stress on the clutch if using launch control?
I don't think I'm going to spend the time on making a customised map 6 since people say map 1 feels slightly more responsive and it doesn't stress the engine/clutch as much. I'm wanting to get 340-350 hp just to be able to kill some m135i/m140i's
Frankly clutch is stressed more in high gears than low. In powerful cars clutch slips mostly when using low rpms and high gears. Maybe someone wiser can elaborate more but this is what Ive understood..?
Sent from my SM-G950F using Tapatalk
It wasn't me, map 1 is just a preset of settings that can be used in map 6. Just a shipping map as such so people can fit it and enjoy without using the data cable.I see. Don't know if it was you but someone also talked about the car feeling more like a natural aspired car by moving the power band up.
Just made the below settings as a mock up with intended max boost in 1st set to 3.5 psi. I have to ask George about if this can be run with 95 ron fuel, or if I should stay below 4.5 psi similar to map 1.
rpm psi
1500 0,0
2000 1,0
2500 2,0
3000 3,0
3500 4,0
4000 4,2
4500 4,5
5000 4,8
5500 4,8
6000 4,8
6500 4,5
7000 4,0
Map 1 is safe for 95 ron I believe but always best to log the car and find out
I know the differences between the maps, but I didn't knew what settings were used in map 1 since 4.5 psi is just stated as the average additive boost.
However I think I'll just write George from BMS when I get the JB4 since map 6 makes more sense now. Thank you for your help.
U can run map 1 and set the boost by gear on 1st, 2nd or 3rd for less stressing n less excessive wheelspin.I've been reading a lot on different forums about JB4 and I can't seem to find a definite answer to below question:
