I had A8 D3 today for some vcds tweaks but due to battery issue couldn't do much. The battery died half way through while I was trying to clear the fault codes so after jump start. Had to re run the auto-scan and clear the fault codes. Almost every code was voltage related. Need advise what could be the cause of it.
Code:
Saturday,22,July,2017,18:15:32:25423
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 17.1.3.0
Data version: 20170320 DS267.7
www.Ross-Tech.com
VIN: WAUZZZ4E36N001868 License Plate:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 11 31 13 15 16 17 18 19 1D 1E 25 28
34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 65 67 69 72 76
77
VIN: WAUZZZ4E36N001868 Mileage: 173890km-108050miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1D-Driver Ident. -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Not registered 0001
67-Voice Control -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E0 910 409 H HW: 4E0 907 409 C
Component: 4.0L V8TDI A000AGMª0010
Revision: --H01--- Serial number: AUX3Z0E3362460
Coding: 0010773
Shop #: WSC 02313 785 00200
VCID: 285FA89A9B90540181-807C
1 Fault Found:
17861 - Exhaust Gas Temp Sensor 1 (G235)
P1453 - 000 - Open or Short to Plus
Freeze Frame:
RPM: 651 /min
Torque: 89.7 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 13.53 V
Temperature: 690.2°C
Temperature: 145.0°C
Inj. Quantity: 8.2 mg/str
Readiness: 0 0 1 1 1
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 L HW: 09E 927 156 A
Component: AG6 09E 4,0LTDI RdW 0020
Revision: --H01--- Serial number: 0056576
Coding: 0000001
VCID: 2C57548A8F68782165-8078
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0008557
Shop #: WSC 02313 000 00000
VCID: 224BBAB2FDACBE51DF-8076
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 907 181 A
Component: FBS AUDID3 H12 0200
Revision: 02005112 Serial number: AUX3Z0E3362460
Coding: 0265216
Shop #: WSC 01223 210 182671
VCID: 58BFD85AEB702481F1-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H08 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
VCID: 2345BFB6E2B6B759D4-8076
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 730 F HW: 4E0 035 729 A
Component: Interfacebox H43 1110
Revision: 00000000 Serial number: 300D9057550044
Coding: 0000002
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
Subsystem 2 - Serial number: 00000000095911
Subsystem 3 - Serial number: 0128.03.120000000100010021ÿ
Subsystem 4 - Serial number: 010021ÿ
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 D
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000064940
Coding: 1136817
Shop #: WSC 02311 785 00200
VCID: 1C37844ADFC888A115-8048
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 L HW: 4E0 907 279 L
Component: ILM Fahrer H12 0210
Coding: 0143121
VCID: 316945FEA84A15C956-8064
Subsystem 1 - Part No: 4E2 910 113 B
Component: Wischer WWS D3 H50 0420
Coding: 00000037
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00139548
Shop #: WSC 02313
Address 11: Engine II Labels: Redir Fail!
Component: 4.0L V8TDI A000AGSª0010
Coding: 0010773
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4E0 910 561 F HW: 4E0 907 561 F
Component: ABSTANDSREGELUNGH03 0020
Coding: 0011155
VCID: 2541A1AEEC824969BA-8070
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11111101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 74
Mileage: 173892 km
Time Indication: 0
Date: 2017.07.22
Time: 00:34:00
Freeze Frame:
Temperature: 30.0°C
Voltage: 13.95 V
Bin. Bits: 00100100
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655 G
Component: Airbag 8.4E+ H10 0940
Coding: 0431707
VCID: 63C5FFB6A236F75994-8036
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0112151
VCID: 65C1E1AEAC0289697A-8030
Component: Lenkradmodul H07 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 980 N HW: 4E0 920 980 N
Component: KOMBIINSTR. VDO H70 0400
Revision: D01 Serial number: AUDID3E3000186
Coding: 0016413
Shop #: WSC 39809 067 57207
VCID: 326B4AF2AD4C2ED12F-8066
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0 815 069 E
Component: Heizgeraet H07 0100
Revision: 0000000B Serial number: 00000009006406
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 1A3B8252D5FCF69107-804E
Address 19: CAN Gateway Labels: 4E0-910-468.clb
Part No SW: 4E0 910 468 B HW: 4E0 907 468 F
Component: Gateway H10 0080
Revision: 10 Serial number: 1800405322004E
Coding: FFFFFFDE2B7504
VCID: 275DABA6968E5B7988-8072
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 74
Mileage: 173894 km
Time Indication: 0
Date: 2017.07.22
Time: 00:26:15
Address 1D: Driver Ident. Labels: 4E0-910-218.lbl
Part No SW: 4E0 910 218 A HW: 4E2 905 218 B
Component: FPI_1 H01 0010
Revision: 01000101 Serial number: 31012005175649
VCID: 1F4DB346CEDE93B9F0-804A
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 E HW: 4E0 035 111 A
Component: CD-Changer H44 0430
Revision: 00000000 Serial number: AUZ5ZBE7145383
VCID: 1B358756DAC68F991C-804E
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0265216
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 A
Component: KLIMA-STG. FOND 015 0220
Revision: 00000018 Serial number: 00000000026399
Coding: 0000000
VCID: 61C9F5BEB82AE54986-8034
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0015520
Shop #: WSC 00011 888 06946
VCID: 2A5B5292859C661197-807E
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H08 0060
Coding: 4063342
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 L HW: 4E0 919 887 C
Component: MNS ECE H44 0690
Revision: 00000000 Serial number: 305DM057583037
VCID: 366376E2412432F103-8062
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H02 0090
Serial number: 00000504700025
Coding: 0036038
VCID: 1D31894EC4D281A9E2-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 802 B
Component: Türsteuer.FS BRM003 0060
Coding: 0028462
VCID: 204FB0BAF3A0AC41C9-8074
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040504050026
Coding: 0004317
Subsystem 1 - Part No: 4E0 907 719
Component: Neigungssensor H03 0020
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 K HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0440
Revision: PROD_01 Serial number: 00000000013092
Coding: 0000011
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000059086
Coding: 0010101
VCID: 1E338E42C9D49AB1FB-804A
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 801 B
Component: Türsteuer.BF BRM003 0060
Coding: 0028462
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000431
Shop #: WSC 00383 210 80878
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000018
VCID: 2643A6A291844271B3-8072
Subsystem 1 - Part No: 4F0 941 329 A
Component: AFS-Modul links H05 0010
Subsystem 2 - Part No: 4F0 941 329 A
Component: AFS-Modul rechtsH01 0010
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 F HW: 4E0 035 541 E
Component: TUNER EU/US/RDW H42 0480
Revision: 00000000 Serial number: 396DR057507702
Coding: 0000001
Address 57: TV Tuner Labels: 4E0-910-146.clb
Part No SW: 4E0 910 146 E HW: 4E0 919 146 B
Component: TV analog TUNER H13 0270
Revision: 00000010 Serial number: 00000000001317
Coding: 0001003
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: ENERGIEMANAGER H12 0480
Revision: 00000000 Serial number: 00000000005469
Shop #: WSC 00958 210 51185
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 300410A23L
Coding: 34453039313531303541205641303330303431304132334C
Shop #: WSC 00383 210 83674
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0060
Coding: 0028462
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01
Revision: 00010028 Serial number: 00000700031509
Coding: 0202328
VCID: 5FCDF3468E5ED3B9B0-800A
1 Fault Found:
01477 - System Switched Off
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 74
Mileage: 173894 km
Time Indication: 0
Date: 2017.07.22
Time: 00:32:21
Freeze Frame:
Speed: 0.0 km/h
Temperature: 19.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 D HW: 4E0 035 753 A
Component: SDS 3502 UK H45 0560
Revision: 00000000 Serial number: 00000503300059
Shop #: WSC 12336 024 394758
Address 69: Trailer Labels: 4E0-910-383.lbl
Part No SW: 4E0 910 383 B HW: 4E0 907 383 B
Component: ANHAENGERELEKTR 003 0040
Coding: 0000001
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0060
Coding: 0028462
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: 06.00.57 Serial number: 00067808720509
Coding: 0111108
VCID: 2149B5BEF8AAA549C6-8074
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 C HW: 4E0 862 335
Component: Handyvorb2 H10 0120
Revision: 00000000 Serial number: 00000007548564
Coding: 0010900
End-------------------------(Elapsed Time: 03:46)--------------------------
