yep, is air con pipe, but clean it and spray some soapy water on it and see if there are any bubbles, can be leak starting from somewhere else. what pipe you got over the air con pipe?
could go from somewhere upper on it and then just dripping from it (gravity), because in air con you will get only gas, eventually check also water hoses nearby, as coolant also seem to be oily on touch.
