Gurpreet Singh
- Joined
- Nov 26, 2014
- Messages
- 19
- Reaction score
- 3
- Points
- 3
Hi,
I've run into a problem since yesterday intermittently whereby my car will crank and crank but not start. Randomly it will start, and randomly it won't. It's happened about 3/10 starts since yesterday, no new codes are showing (except G28 speed sensor), I was told by a friend it may be electrical and looking online it looks like maybe a relay but I'm hoping it's not a fuel or pressure issue.
I'm trying to sell my car and have someone viewing this weekend so don't want to sink too much into the car but I don't want to sell it to someone if it has a big problem. Any advice is appreciated - I'm aware of the airbag MIL and rear left light along with the alarm codes:
Code:
Friday,23,June,2017,21:17:55:11979
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.1.3.0 (x64)
Data version: 20170320 DS267.7
www.Ross-Tech.com
VIN: WAUZZZ8E64A071458 License Plate:
Mileage: 157660km-97965mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUZZZ8E64A071458 Mileage: 157660km-97965miles
Address 01: Engine Labels: 079-910-560-BBK.lbl
Part No SW: 8E0 910 560 B HW: 8E0 907 560
Component: 4.2L V8/5V G 0020
Coding: 0011771
Shop #: WSC 33278 133 00032
VCID: 2443AFDBE4F53461AD-515A
2 Faults Found:
17979 - Left Engine Mount Solenoid Valve (N144)
P1571 - 001 - Short to Plus
16706 - Engine Speed Sensor (G28)
P0322 - 004 - No Signal - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 8E0 910 156 HW: 09L 927 156
Component: AG6 09L 4.2L5V RdW 0020
Revision: 00000001 Serial number: 0001719
Coding: 0001001
Shop #: WSC 63351 000 00000
VCID: 63C1ECC7A17B735994-515A
No fault code found.
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 Q
Component: ABS/ESP allrad 3033
Coding: 04597
Shop #: WSC 06435
VCID: 366765931269B6F103-513C
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AA
Component: A4 Klimaautomat 1219
Coding: 00000
Shop #: WSC 63351
VCID: 60CBE3CBE06D684189-515A
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul RDW 0517
Coding: 00011
Shop #: WSC 63351
VCID: 3565629F0F6FBDE90A-4B32
2 Faults Found:
00984 - Left Tail Light (M4)
57-00 - Electric Circuit Failure
01312 - Powertrain Data Bus
79-00 - Please Check Fault Codes
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 B
Component: Airbag 8.4EP 3002
Coding: 0010602
VCID: 366765934269B6F103-515A
1 Fault Found:
01217 - Side Airbag Igniter; Driver Side (N199)
001 - Upper Limit Exceeded - MIL ON
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 01141
Shop #: WSC 63351
VCID: 3E777DB33A597EB1DB-4B32
2 Faults Found:
00576 - Terminal 15
57-10 - Electric Circuit Failure - Intermittent
00883 - Ignition Switch (D) Terminal S
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 980 L
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 01400
Shop #: WSC 00001
VCID: 3565629F0F6FBDE90A-515A
Subsystem 1 - Part No: 71458
Component: AUZ6Z0C0081035
71458 AUZ6Z0C0081035
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
VCID: 6BD184E719AB3B192C-513C
Address 46: Central Conv. Labels: 8E0-959-433-MAX.clb
Part No: 8E0 959 433 BC
Component: Komfortgerát T3B 1311
Coding: 06891
Shop #: WSC 63351
VCID: 73E19C87419BE3D9E4-4B18
Subsystem 1 - Part No: 8E2959802B
Component: Tõrsteuer.FS BRM 0003
Subsystem 2 - Part No: 8E2959801B
Component: Tõrsteuer.BF BRM 0003
Subsystem 3 - Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0003
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0003
3 Faults Found:
01134 - Alarm Horn (H12)
49-00 - No Communications
01366 - Opened Due to Crash Signal
35-00 - -
01561 - Rear left door
61-10 - Won't De-Safe - Intermittent
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 63351
VCID: 0403CF5B1435D461CD-4B4A
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 186 J
Component: concert II GRO 0008
Coding: 01202
Shop #: WSC 63351
VCID: 2E574DF3EA398E314B-4B18
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No: 8Z0 919 283 A
Component: Parkingsyst. A4 RDW D09
Coding: 01104
Shop #: WSC 06435
VCID: 43810C4751BB1359B4-5178
2 Faults Found:
00625 - Vehicle Speed Signal
27-00 - Implausible Signal
01550 - Signal for Reverse Gear
27-10 - Implausible Signal - Intermittent
End-------------------------(Elapsed Time: 05:28)--------------------------
