Audi A4 1.8t Sport 1997 B5 I have tried to educate myself on the different Supension types for my car..
This is where I am at the moment the car as the standard sports suspension on it and I was thinking of putting the B12 Pro suspension Kit on it which I understand to be Eibach lowered springs 30mm all round with the Bilstien B8 Dampers on..
Or the Eibach B12 Sportline springs which will give you 45-50mm Front and 35-40mm Rear..both are about the same price as it happens..
I have heard about the better ride on both these kits compared to what I have now and that is a given..
My probelm is the look of the drop 30mm all round Pro Kit or the Lower 45-50mm Sportline kit..
My car at the moment sits quite high at around 55mm-60mm front gap and 55mm on the rear gap tyre to bodywork...
With either of these kits you are not getting the true measurements as stated because they are going on a standard A4 not the sports suspension which is lower...
So having said that going with the 30mm would not drop it much and you might not see very much difference from what I have now..
On the other hand is the Sportline kit too low for the car driving wise...
I was wondering what you guy's here thought and I assume some of you have been through this problem...
Any advice would be greatfully received...
