Morning,
I have been offered some S3 speedline multispoke wheels - 18" PCD is 112 and the off set is et56
Will they be a straight fit on my car? A3 3.2 v6 2004
Morning,
Morning mate
Yes they will fit straight on... but if you have big brakes then you should go for something like et47
The higher the et (e.g. et56), the inner the wheel will sit
The lower the et (e.g. et35), the outer the wheel sits... and the closer it gets to the arches
But people tend to avoid wheels with et35 as they are too close to the arches and it might get a little contact...
I myself have always had low et wheels like et30 on a set of BBS CH and they where touching the rear arches a bit but I didn't care because I was after stance than comfort ride
