Elf458_123
- Joined
- May 19, 2017
- Messages
- 6
- Reaction score
- 1
- Points
- 3
Hi,
I was on here as elf458 but lost password and can't get a reset so new account. Maybe some will remember me...
So I've got an asb 3.0 tdi and it had the turbo actuator fail. The motor died so replaced with a working new part. I've manually calibrated movement with vnt arm limits and tried to calibrate on odis and vcds but it doesn't seem to respond under the calibration sequence via the diagnostics port. Motor moves when unplugging the wiring connector and the vnt movement is completely free with no resistance. The wiring plug produces the appropriate voltages when running output tests on vcds. I'm completely stumped what to do next. Nothing seems wrong but just won't respond to calibration. Can anyone shed some light???
Thanks in advance
Thanks in advance
