Hi,
My parking sensors haven't worked for awhile now. Is it a simple job that I could replace the parking control module?
My passenger door locks and unlocks when it feels like it. Do I need a new motor according to the log?
How do I address the other issues? I think the radio issue is because I have an aftermarket headunit.
01-Engine -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CAX) Labels: 03C-906-022-CAX.clb
Part No SW: 03C 906 022 AN HW: 03C 906 022
Component: MED17.5.20 2732
Revision: D5H03--- Serial number: AUX7Z0H7FN80EO
Coding: 0000072
Shop #: WSC 06314 000 00000
VCID: 688AB1B0DE786F47859-803C
No fault code found.
Readiness: 0110 0101
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 13424012092500FAC80B02E6901E00803800
VCID: 74B2D5C09EB09BA7391-8020
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BG HW: 8P0 820 043 BG
Component: KlimavollautomatH09 0100
Revision: 000110 Serial number: 8P0820043BG
Shop #: WSC 00000 000 00000
VCID: 72BED3D8E8A495972BD-8026
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000008799386
Coding: 11AC2F81B0141380EF00001C0000000000084E0564010403002800000000
Shop #: WSC 06314 000 08192
VCID: 48CA5130BEB84F47A59-801C
Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
Address 10: Park/Steer Assist (J446) Labels: 8P0-919-475-7X2.clb
Part No SW: 8P0 919 475 D HW: 8P0 919 475 A
Component: PARKHILFE 8K H06 0102
Revision: 11001001 Serial number: 84640818300744
Coding: 000003
VCID: 3FD84AECE77608FF143-806A
1 Fault Found:
16347 - Control Module - EEPROM Error
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Temperature: 0.0°C
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 303142383038303030374A55305238503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 49CC5434A932B64FBA7-801C
Crash sensor for side airbag: driver side:
Serial number: 3572DRB400007A28FB1/
Crash sensor for side airbag: front passenger side:
Serial number: 3582DRB400007A28B32U
Crash sensor for side airbag: rear: driver side:
Serial number: 35128RB400003FAE3D7/
Crash sensor for side airbag: rear: passenger side:
Serial number: 35228RB400003E408D7P
Crash sensor for front airbag: driver side:
Serial number: 35547RB400004000425
Crash sensor for front airbag: front passenger side:
Serial number: 35647RB400003FFF336+
1 Fault Found:
13635840 - Supply voltage
U1011 00 [008] - Voltage too Low
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 26
Mileage: 77322 km
Date: 2017.03.25
Time: 00:07:41
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0002012
VCID: 41DC4C149D827E0F627-8014
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
1 Fault Found:
01304 - Radio
004 - No Signal/Communication
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 E HW: 8P0 920 982 E
Component: KOMBIINSTR. VDO H18 0830
Revision: D0H18006 Serial number: 2247H006002514
Coding: 0004428
Shop #: WSC 12345 123 12345
VCID: 3B203EFCFF6E14DF38B-806E
1 Fault Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 78143 km
Time Indication: 0
Date: 2017.04.29
Time: 07:21:08
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K088050915
Coding: E9A07F060002022103
VCID: 353428C4D94AC2AFCEF-8060
1 Fault Found:
01304 - Radio
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 22
Mileage: 78143 km
Time Indication: 0
Date: 2017.04.29
Time: 07:21:14
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H18006 Serial number: AUX7Z0H7FN80EO
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0060
Coding: 0000692
VCID: 43D0461C879E6C1F70B-8016
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 232 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2A0E0BB800F49D5753D-807E
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1980200002186D0985054C9FC637
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.clb
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000692
VCID: 44D2450082906B27491-8010
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000144
Shop #: WSC 06314 000 1012544
2 Faults Found:
00098 - Rear Left Central Locking (Safe) Motor (V163)
012 - Electrical Fault in Circuit
00930 - Locking Module for Central Locking; Rear Left (F222)
008 - Implausible Signal
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0000144
VCID: 42DE4318988465177BD-8016
End----------(Elapsed Time: 01:16, VBatt start/end: 14.4V/14.3V)-----------
