Hi, I'm wondering when others S-tronic upshift and downshift in auto.
As mine has just changed when it does it. It just had a gearbox oil and filter change last week. So thought I might feel a wee difference ..
Strangely yesterday on a short run it was going into 6th at 30mph , and holding 4th till 15 mph.
Took it for a longer run and it was upshifting less earlier but earlier than the last month I've had it.
So now it seems more settled and shifts up to 3rd at 18mph, 4rd at 22mph, 5th at 28mph, 6th at 36mph, and 7th sometimes at 43mph.
It will hold on to 4th slowing down till 15mph sometimes , say coming up to a junction , then seamlessly go down to 2nd and first if needed.
And I am getting better MPG around town now , but not on motorway.
Gear changes from 3rd up are seamless, I often can't tell it's changed gear. But 1st to second is always a bit draggy or lumpy compared to other gears (but none worse than any other auto I've driven with ZF box) , Seems like it is riding the clutch / torque converter.
Other observation is in manual it takes a second to change up after tapping the paddle. More like it's thinking , then when change happens it's instant .
I've just ran 1000miles feeding it V power nitro and Momentum 99 , so don't sure if this may have flipped the ECU to produce more torque lower down to enable earlier upshits - does the ECU talk to the gearbox ?
First time with an Auto / S-Tronic so I'm still getting used to it and know it's way different from a manual!
So would like to hear others observations
