killa kombo
Good Morning
I have a 2004 8P Pd140 BKD. 145k
When im driving along i will get a low coolant warning, ill pull over and my tank will appear empty, when i release the cap 'whooosh' the coolant will rush to the max level. This will happen every 20 minutes while driving the car normally. As the reservoir pressurises it pushes the coolant through the over flow (im guessing) whilst driving, I do have to up a litre coolant every other day. I will get the low coolant warning seconds after the temp gauge hits 90. When the heating is on it is barely luke warm, if that.
Work I've done:
I will be doing a heater matrix flush next to see a possible blockage is the reason for the pressure build up and lack of heat in the cabin.
is it an air lock? blockage? my local indy doesn't have a clue either charged me £50 to put a £4 leak detector dye in the coolant, no luck.
If any one could help me out that'll be great.
Thanks in advance
Work I've done:
- New cap and Reservoir
- Coolant Flush and New Coolant 5050 G12
- New thermostat Genuine part
- New coolant temp sensor Genuine Part
Thanks in advance
