Soooooo...
Crank pulley off
Old stud removed and replaced with new stud torqued to 20nm
Tensioner dampener on and torqued to 11 (is that right?)
Tensioner roller on but loosely nipped up
Cambelt slipped on. Think i have enough tension on the tight side but no idea for sure
The timing marks on crank are spot on. The timing marks on cam is ever so slightly forward but i think this will drag back once I put tension on the belt and pull the pin. What do you think?
Crank pulley off
