- Joined
- Jul 30, 2016
- Messages
- 425
- Reaction score
- 122
- Points
- 43
What if I just replace the PCV and gasket with the revised parts and given the low mileage 2 - 2.5k I cover annually am I safe?
Okay, I was using Mobil 1 ESP 5W 30 last year but this year changed to Castrol Edge 5w30 LL as I was told castrol is better for Audi, since changing it I couldn't tell any difference.
Quick question can I mix the 2, reason I ask I have 3 litres of each mobil left from last year and castrol unused and when that is done then go the 5w40 route.
I had also been using mobil 1 esp 5-30 and for a while , and I was allways topping up the oil, last month I did an oil service etc and starting using Fuchs Titan Race Pro S ,5w-40 ester , results speak for themselves , over the same milage etc I would have used approx. 500ml of the mobil 1 ,with the titan I've hardly used any and I drive my car the same whatever oil is in it, so that's sealed it for me frankly, and I don't get the hot engine oil smell now either that I sometimes had with the mobil1.
just my experience chaps.
Where can i find this database?these are the part numbers from database, you can see which are BUL items.
I rang my local audi dealer and they said "N" was current listed pcv for the BUL, maybe a call to audi Uk may resolve the confusion amongst dealers...As per Audi... Apparently the "R" (06F29101R) Is the current revised version for my chassis though not entirely sure what the difference is between the two?
