Hi all
My dipped beam appear to be very very dipped at the mo (almost dangerously low as I can't see beyond 30m in the dark unless using full beam).
The self test when turning the ignition on is fine and the full beam works as normal so I'm thinking the gizmo that decides the angle of the headlights isn't working properly. Am I right in thinking this is just a lever type device attached to the front suspension which moves during weight transfer on the car and is it easy to locate. Also is there a way of diagnosing the headlight angle in VCDS while driving to see if it is receiving any data from the levelling sensor/lever.
Hope this makes some kind of sense
Dave
Dave
