Big Turbo
Well I knew it would be only a matter of time before I fitted a bigger turbo.
So it all came together in the Christmas / new year break.
To be honest I had the turbo before I had even purchased the car. It was a nice unit and when it came up for sale I just had to have it.
The turbo itself started is a borg warner John Deere s200v. As stock the turbine is really healthy as 56mm ex but only 44.5mm ind compressor wheel. Lucky for me the unit came modified with a 70/51mm CW. The compressor housing also came with anti surge modification already done.
Turbo pictures
Parts collection - Oil return, feed, compressor housing outlet, flange, V bands etc
The green cable is the turbo speed sensor
S200 Vs 2260 compressor housing
Fitting
Turbo unit removed
Custom oil return
Custom oil feed
Modified 3" downpipe
Modified the Y collector and welded the S200 flange directly to it.
Y collector also housed the EGT probe (cut the boss from a broken 2260) and emp adaptor.
The actuator set up was a very fiddle job - getting the angle and throw correct in relation to the turbo lever took a lot of hours.
But finally a VCDS output test could be done with no errors
Ignore the TIP it was something just to get the car running.
After deleting the EGR cooler water pump, temp sensor and rad outlet sensor I noticed the lambda sensor wasn't behaving itself.
Turns out the rad outlet sensor is used some how to make the lambda sensor to function.
That meant I had to plumb the sensor back in.
Heat protection
Bi Turbo MAF
As the stock MAF sensor was maxed out at 900kg/h the options were map based smoke limiter (time consuming to get right) or bigger MAF.
For a cleaner tune decided to go with the A6 Bi turbo MAF rated upto 1400kg/h so nice improvement over stock.
The housing is bigger over stock so custom 90mm TIP was needed, but on a plus note the MAF fitted the stock air filter perfectly.
Looks pretty good
Dyno result
420hp / 830nm
As you can see the power is still going up at 4k but egt was already 900deg so kept it safe.
Maybe more rail pressure next.
