- Joined
- Oct 3, 2015
- Messages
- 204
- Reaction score
- 4
- Points
- 18
The car is a audi a4 b7 2.0 tfsi se
MASS AIR FLOW Meter
(been told by audi that its faulty and running lean so need a new one , so need clarification this would be the replacement and more up to date revision)
is this item also already in the uk?
http://www.europaparts.com/mass-air-flow-sensor-06d906461.html
cam-chain-tensioner, how easy is it for my local garage to check to see if this needs replacing? and is this the current revision.
http://www.europaparts.com/cam-chain-tensioner-service-kit-2-0t-fsi.html
PCV, is this the current revsion and how would the garage know if the one on the car needs replacing
http://www.europaparts.com/breather-update-kit-a4-b7-2-0t-early-vin.html
clutch line,are there any better ones?
https://www.earls.co.uk/earls/preassembled/clutchlinekits/carclutchlinekits.html
gas-tank-cap,is this the current revision
http://www.europaparts.com/gas-tank-cap-4f0201550j.html
coils,is this the current revision
http://www.awesomegti.com/red-ignition-coil-pack-set-2-0tfsi
thoughts, the rear shocks need replacing so i have decided might aswell do the front and rear, are these a good set
http://www.awesomegti.com/car/audi/...avant-b6-b7-8e-with-sport-suspension-11-00-07
Do i get 2 of these or do they come in dual packs? for the front and rear,and whats the difference in power between 255 and 288 (think those were the sizes)
http://www.larkspeed.com/shopper/i/...lack-Diamond-Rear-Brake-Discs-Grooved-Drilled
http://www.larkspeed.com/shopper/i/...ack-Diamond-Front-Brake-Discs-Grooved-Drilled
http://www.larkspeed.com/shopper/i/...m-Disc-Black-Diamond-Predator-Rear-Brake-Pads
is it just one set of these or do i need how many for front and rear for the brake lines
http://www.larkspeed.com/shopper/i/23DHK622
econ light always on., anybody know as to why?
was told their a suspected air leak from the engine, would this be the pcv or something else?
MASS AIR FLOW Meter
