I'm planning to buy a Bluetooth OBD2 dongle to generally pull stats off the s3, but what app should I be using? My smartphone os is android.
Matt
Matt
I'm sure someone once told me they'd heard of issues with the mini ones not connecting properly?I received my OBD2 bluetooth elm 327, I can only assume this isn't compatible with torque or my car. What do I need to make this work?
I bought this.
http://pages.ebay.com/link/?nav=item.view&id=271623595403&alt=web
i got one of these as well - it tries to connect but can't in the end then asks me "are you sure your ignition is on"I received my OBD2 bluetooth elm 327, I can only assume this isn't compatible with torque or my car. What do I need to make this work?
I bought this.
Ignition on as in engine on? Or can just be turned to ignition?http://www.ebay.co.uk/itm/like/WiFi...r-Tool-For-iPhone-Android-Mobile/191603532932
I have had this type for over 3 years now, works in alfa, bmw, citroen, vw and audi - I always use android torque.
you need to have the ignition on in some cars
booooooo
Might send mine back for a refund and get one of these "trusted" ones. LOL
Just ignition but I dont think it mattered on s3 compared to other cars. It runs through a load of protocols then "connected to ecu"
Maybe buy a different dongle - they are only 5-6 quid, it must be paired with the device otherwise you won't see those messages.
Still haven't tried the free version of vagcom yet to see what the abs issue is. I hope a wheel sensor, but reckon it is the longitude sensor, as only occurs hard acceleration or hard braking.
http://www.zzottel.de/index_en.html im using this!!!
i bought one of these, works perfectly. on off button and a light so you know its on. tried with sony z1c and z3c. need to make sure you pair it as a BT device first.
http://www.ebay.co.uk/itm/ELM327-Bl...tch-Android-/111328743157?hash=item19ebb5cef5
