64 plate A6
Poseidon77
Just bought my first Audi in yrs, an A6 tdi ultra in white. However I do not have a cable to connect my I pod ! Can this cable be added to the mmi. Any help will be appreciated.
Not sure from your question as to whether you simply do not have the cable, in which case a trip to the dealer will sort the problem, or whether your car does not have the AMI system. If it is the latter then yes it can be fitted and Kufatec do a kit https://www.kufatec.co.uk/shop/en/Audi/A7-4G/AMI-Audi-Music-Interface-Retrofit-Audi-A6-4G-/-A7-4G1, note there is a different kit if your car has the 3G+ Sat Nav, and the dealer sorted out getting it installed on my previous C7. May be worth asking a local dealer if they have a "tame" installer as I was told at the time this was a very common retrofit
Went to the main dealer today to be told that my radio is a low spec one with no ami cable or usb . I only have blue tooth or aux, on asking if a ami or usb could be fitted I was told no. On asking if I could fit an upgraded radio I was also told no. So I am a bit confused at the momment as what to do......
As per my previous pose AMI can be fitted as it was done on my previous car, the dealer does not know what he is talking about. Where in the country are you? I could put you in touch with the person that fitted mine if it makes sense. Alternatively do a search for retrofit Audi Music Interface and you will find a number of companies offering the service. All of that said you may find that copying your music to an SD Card is just as effective and a lot cheaper
elan2s whats the best layout for music on sd card? as I've tried loads of ways and most can't be read by car
