Ok I know the xenon topic has been done to death but I'm having a major headache here and I need some input....
I have xenons I've just retrofitted I got the harness from kufatec, ok so as per there fitting instructions I fitted up and coded which tbf I already knew what to do.
I moved from halogens with drl, to bi-xenon with drl..... Now upon fitting xenon work fine no issues main beam and low beam cool..... But for the life of me I can't get the drls working I've coded correctly, I've fitted the drl wires into the 2 positions I knew to fit too. (a3+d3) I just can't get the things to light up... Can I check to see if they do light up ie run a 12v to them or what? I've spent the last 4 hrs on this and I'm ripping my hair out.... I'm no novice just getting totally pee'd off now.
