Well... yes and no... essentially you just need to remove the three bolts, the turbo dro[ps down a bit and you can replace the gasket... fit new bolts (DO NOT LOSE THE THICK WASHERS!!... they are like 4-5 quid each and required...)
The biggest issue is getting the old bolts out... need an E14 (I think, can't remember if its E12 or E14 off hand...) I have found using the blow torch on the bolt head helpful to 'ease' them off...
The other thing to watch out for is the threaded inserts backing out... if they do that then the gasket will be next to useless and will just blow again... if this has happened then thats a little trickier to sort out as you need to gain clearer access tot he inserts to wind them in... if they are loose enough you may be able to use a suitably sized flat blade to catch the threads enough to wind it in... else you will need to unbolt it from the the support bracket and possibly remove the DP to allow enough movement to pitch the turbo back to gain access to the inserts
Its not unusual for the inserts to wind out if the bolts comes loose (which they do) or if the gasket has been replaced before
<tuffty/>
