B8 TDI mod from single exit to dual exhaust? What options?
chazd
Have a dual exit diffuser to fit to replace the single exit diffuser for a 168TDI CR avant.
What exhaust options are there to get a full exit setup? Aftermarket or do any stock exhausts bolt on?
Single exit each side is the plan.
Will an A5 2.7/3.0tdi exhaust fit with a slice and sleeve as you have done? Going to keep OEM unless a cheap aftermarket pops up.
I had custom quads with box delete for 500ish all in at EMP Performance, fully rate them, top boys.
170cr too, sounds a little more throaty and can hear the turbo better when giving it a 'spirited' run, but no rude boy noises or droning which is perfect.
Pictures somewhere in my build thread.
So it looks like custom is the way forward then!? Was hoping the 2.7/3.0 tdi exhaust would fit on..
I saw someone on here had a S4 exhause put on, but it will still probably be cheaper for custom :)
