Hi,
I have an Audi A4, 1.8T, year 2002
I'm trying to recode the abs module using the rosstech video tutorial
That's how I try :
1) Switch ignition On
2) Connect the VCDS to my car
3) Go to ABS Brakes
4) Then I go to this link http://wiki.ross-tech.com/wiki/index.php/Audi_A4_(8E)_Brake_Electronics_(Bosch_5.7)
5) There I select my type car , than [03] - brake electronics & than Bosch 5.7
6) There is nummbers I need , if I understand it correctly I need Login 09575 & Coding 04275. Correct ?
7) Than back in VCDS I select Login and enter 09575
8) Than I select Coding and enter 04275
And right now my problems begin
VCDS reconnect's to ABS , than it shows that soft coding is 00000 & wsc 00000
And nothing happens.
Can anybody explain what I doing wrong , why I can't reprogram ABS ?
I posted a vido on youtube with the problem.
I've tried with diferent VAG-COM cables. Same thing every time.
Does anyone know what to do?
That's how I try :
3) Go to ABS Brakes
