Droning noise when off load - 2009 s3 sportback
dave_ph
Active Member
Somerset
Hi all
Back in Dec 2014 I changed my front tyres to Michelin PS3's. Straight after doing this I got a droning noise which was audible from 12mph upwards, getting higher pitched as speed increased. I put the half worn rears (can't remember what they were) on the front and new PS3's on the back and the noise went. I've just changed my the other 2 tyres and the noise has come back but only when offload/decelerating. I swapped the wheels around but makes no diff.
The noise disappears at around 20mph however the faster the car is going, the higher pitched it gets (and a bit noiser). As soon as I press the accelerator, the noise goes away and is fine no matter how hard I accelerate.
I've got an s-tronic gearbox. I've put it in netrual however doesn't make any difference. Also doesn't seem to make any difference whether I am turning or braking. There isn't any vibration at all
Has anyone got any ideas what it might be or had similar issue?
Are both sets directional tyres,I read somewhere that they shouldn`t be mixed .
I personally wouldnt think it would matter!
Ive had PS3's for a few years on a couple of cars with nill noise issues.
Run your hand along the inner tread blocks and feel for feathering.
If so an alignment is needed.
It's got asym Michelin PS3's on all round now which is when the problem reared up again. I had PS3's on my old s3 and was never a problem!
I'm guessing it's the greater rolling resistance of the PS3's highlighting an issue that may have already been there as I can't see why the tyres alone would cause it
I wondered if it would be alignment but the tyres that came off were fine and it only happens when off load
I should probably add that the guy who did the tyres for me stood on the side of the road while I drove past and couldn't hear the noise from the outside, just said it was normal tyre noise
Further to the above, on my drive home I tried sharp turns and braking which didn't make any difference to the noise. I also stuck the gearbox in netrual and turned the engine off while moving along and the noise persisted
So if not tyres may be a mount, driveshaft donut, rear diff, etc
I was thinking wheel bearing but I'm assuming the noise is coming from/caused by the front axle as when I did the front tyres originally and the noise started, putting the older rear tyres on the front stopped it. I then did some sharp turning yesterday which didn't effect the noise which I thought it may have done if it's a wheel bearing as it would have been loading the weight on each wheel in turn?
I had dad drive the car earlier and I sat in the back and had the seats down and listened in the boot area. The noise is definitely coming from the rear and sounds central to passenger side. There's quite a bit of vibration coming from there as well. I went round a roundabout at speed to load that wheel up and it didn't make a difference. I jacked the car up and check the wheel for wobble and also the drive shafts which were all fine. Also checked for any leaks around the rear diff and haldex which all looked fine
Sounds like you've been very thorough in your search for the problem.
One thing I will say from experience - when my front passenger wheel bearing was knackered and noisy, it was 'fine' when the mechanic was doing the wobble test.
Same thing when I changed front wishbone bushes. That leads me to believe the Audi tolerances are too tight to check manually.
Are the 'noisy' tyres brand new? Sounds like one or both are feathered. That can give the noise your describing. Run your hand back and forth over the tread for rough/sharp areas. I had this occur and my previous BMW and on my current A4...
Heh thanks, I like to give as much info as possible as it could be so many things. I've heard the same about the wheel bearings not wobbling so could still be the problem.
The front tyres are brand new, but the rears are 8 months old now. I've swapped front and rear over a couple times and the noise remains the same and in the same location. If anything, it's starting to get worse.
It's a strange comparison, but as the car slows down and the droning gets lower pitched, it's a similar sound to when a tube train is slowing down and coming to a stop. My mind works in weird ways lol
Check for a sticking caliper/warped disc. Are the alloys/tyre hot after a drive?
