Hi guys,
I was wondering if someone could shed some light on this for me as it's starting to drive me crazy-
I have an A4 1.9 TDI (engine code BRB) and every week I check the coolant and it's always loosing a small amount very time I check. If I fill up the expansion tank anymore than half way between the 'max' a 'min' line it just chucks coolant out of the overflow.
I can't see any signs of leaks either.
The coolant is crystal clear and no indication of coolant in the oil. The water pump was changed about 10,000 miles ago and the thermostat was change at about the same time too.
I don't think it's a head gasket issue as the the coolant pipes I'm able to squeeze and would expect them to be really hard from the system being overpressurised.
One thing I have noticed very recently when I drive the car within the first minute or two is I can hear what sounds like water/coolant in a pipe flowing which I'm guessing is going through the heater matrix?
After that first minute or two I never hear it again until I use it the next day when I drive it.
Many thanks
Many thanks
