- Joined
- Dec 3, 2008
- Messages
- 10,887
- Reaction score
- 4,888
- Points
- 113
Well, it had to happen didn't it!!
Things were going very well and I was due to pick it up Friday evening to give it a trial.
Rick calls me with a voice that tells you everything.
"Mate, its smoking"
Dropped onto 3 cylinders, cylinder 2 misfire.
Long and short of it, the same valve guide has become loose again.
It arrived on Saturday morning on a recovery truck and yesterday I stripped it in a record time of 1hr 55 mins (done it that many times)
Heads off again ready to go back... But this time we're not using the new head that I bought as we think this could be an Audi test head that's slipped through the net (or out of the back door) which under high temperatures is expanding more than it should and causing the guides to come loose.
So with respect to my head builder...
He is taking my older CDL head and fully porting and polishing it again etc etc and basically making another head for me foc.
**** DO NOT BUY A BRAND NEW HEAD FROM EBAY THAT SHOULD BE £2500 FOR £500 AND EXPECT EVERYTHING TO RUN SMOOTHLY *****
That's my lesson anyway.
On the plus side, 2 maps, one with 25psi of boost and the other with 30psi, pulls hard all the way to 7500 rpm with no issues
(Apart from what developed later)
26psi equates to roughly 450bhp going from maf readings and AFR etc. Just to give you an idea of what its pushing.
Other than that Rick was very impressed with the build and it responded very well to all aspects.
My favourite line of all time was "when it comes back and all is running well with no issues, I think we can really run some man boost in the mid range and open the Rev limiter a little more"
Also the wmi isn't even being used at this stage.
Basically it's looking good for the figures. Holding 30 psi of boost through out the Rev range is just epic anyway so we've already achieved what we set out to achieve.
So a week or 2 and I should have some more Info with a little more positivity
Hi Craig,
Really sorry to hear that.
You've had to work so hard and had so many setbacks that it's about time you had some good luck as opposed to all of this.
I would have thought from what you've said,that 2bar there is going to equate to around 500bhp,so that's an excellent result,and maybe in one way the full power/full throttle run was useful to pick up a potentially catastrophic failure before it happened.
Very best of luck.
