ade-55
Alright folks as it states when it's cold it really crunchs when trying to get into second gear. When warm it doesn't happen. Is it a common problem? Maybe gear linkage? It's had a new clutch 6 months ogo. Thanks in advance
gearbox oil is never due a change. It's a sealed unit from the factory and there is no fluid change interval.
That said, it's not a bad idea after 100k+ to drop the box oil and change it.
it's not likely to fix your crunch though. Mine does this also for the first 1-2 changes from stone cold.
As a counter, I tend to pull away in 1st, then drop to 3rd and cruise to the end of my road. By the time I next go to grab second it slides in just fine.
You'll need either a funnel with a long neck, or my preferred choice, a massive syringeAlso don't surpose anyone does know if I will be able to access the filler hole on the gearbox without a pump of some kind? Cheers
