Saturday,23,May,2015,22:05:55:08412
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0
Data version: 20150311
www.Ross-Tech.com
VIN: WAUZZZ8EZ1A073697 License Plate: Y50 TAY
Mileage: 232390km-144400mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUZZZ8EZ1A073697 Mileage: 232390km-144400miles
Address 01: Engine Labels: 06B-906-018-AVJ.lbl
Part No: 8E0 906 018 B
Component: 1.8L R4/5VT 0004
Coding: 11701
Shop #: WSC 00000
VCID: 2757D155C5CDC8190F5-5122
WAUZZZ8EZ1A073697 AUZ6Z0A0055809
3 Faults Found:
17524 - Oxygen (Lambda) Sensor Heating; B1 S1
P1116 - 35-00 - Open Circuit
17511 - Oxygen (Lambda) Sensor Heating; B1 S1
P1103 - 35-00 - Performance too Low
17522 - Oxygen (Lambda) Sensor; B1 S2
P1114 - 35-10 - Internal Resistance too High - Intermittent
Readiness: 0010 1101
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 A
Component: ABS/ESP allrad D1320
Coding: 04275
Shop #: WSC 06435
VCID: 2649DC51C2C7D111343-5140
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-10 - - - Intermittent
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043
Component: A4 Klimaautomat 0508
Coding: 00000
Shop #: WSC 00000
VCID: 5EB9B4B1DA1749D13C3-5122
No fault code found.
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279
Component: int. Lastmodul RDW 0510
Coding: 00001
Shop #: WSC 00000
VCID: 6FE7F9752DBDD059875-4B04
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655
Component: Airbag 8.4E 3001
Coding: 0010602
Shop #: WSC 63351 000 00000
VCID: 74EDF619149BF3817A7-5140
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 F
Component: Lenksáulenmodul 0302
Coding: 00001
Shop #: WSC 63351
VCID: 36690C111267A191843-4B04
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 D
Component: KOMBI+WEGFAHRS. RB4 D14
Coding: 01400
Shop #: WSC 00484
VCID: 2A512861D6DFF57110B-5122
2 Faults Found:
00562 - Sensor for Oil Level/Temperature (G266)
30-00 - Open or Short to Plus
01304 - Radio
49-00 - No Communications
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0503
Coding: 00001
Shop #: WSC 00000
VCID: 6BDFED6519A52C79ABD-5140
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 AK
Component: Komfortgerát T1B 0514
Coding: 06859
Shop #: WSC 63351
VCID: 7AF1D82166FF85F120B-4B04
Subsystem 1 - Part No: 8E2959802B
Component: Tõrsteuer.FS BRM 4.11
Subsystem 2 - Part No: 8E2959801B
Component: Tõrsteuer.BF BRM 4.11
Subsystem 3 - Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 4.10
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 4.10
3 Faults Found:
01134 - Alarm Horn (H12)
01560 - Passenger Door
61-10 - Won't De-Safe - Intermittent
00933 - Electric Window Motor; Passenger Side (V148)
62-10 - No or Incorrect Adjustment - Intermittent
End-------------------------(Elapsed Time: 06:27)--------------------------
