I have just dremeled out the excess in the std airbox and also had to dremel the bottom edge of the maf as its too big to fit in the recess, now no lip on bottom of maf. Anyway all done and a tight fit!
Question is does the maf to airbox need to be 100% airtight?
As for the maf horn inside the box I was thinking of using a piece of silicon pipe and jubilee clipping it to the maf inside the airbox? Would this be ok? And if I push right against the wall inside the airbox should that be enough to ensure that nothing could come through the outside of the maf as that sanded right down??
Hope that makes sense otherwise I will get pics?
