Every couple of days my engine management light will come on and stay on for a day or 2 and then turn back off , car drives fine, no limp mode etc, recently drove the car 200miles with no issue
Its an Audi A4 2.0TDi 2010 B8
I ran vag-com but cant get an accurate diagnosis on what the 4 problems are and how to resolve
any help is greatly appreciated!!
[Fault 1]
Address 01: Engine (J623-CAGB)
2 Faults Found:
5262 - Diesel Particle Filter; Differential Pressure Sensor
P2454 00 [168] - Short to GND
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 88
Mileage: 119036 km
Date: 2015.03.28
Time: 13:33:12
5162 - Diesel Particle Filter; Differential Pressure Sensor
P2453 00 [096] - Implausible Signal
Intermittent - Not Confirmed - Tested Since Memory Clear
Readiness: 1 1 0 0 0
[Fault 2 - Wiper switch works and seems normal??]
Address 16: Steering wheel (J527)
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 54
Mileage: 119485 km
Time Indication: 0
Date: 2015.04.03
Time: 20:33:02
[Fault 3 - None of the windows are broken?]
Address 46: Central Conv. (J393)
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
3 Faults Found:
01403 - Glass-Break Sensors; Rear
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 220
Mileage: 118261 km
Time Indication: 0
Date: 2015.03.15
Time: 18:45:49
[Fault 4 - SatNav/GPS works fine?]
Address 5F: Information Electr. (J794)
Subsystem 1 - Part No: 4G0 919 884 G
Component: EUR 2010 1108
Subsystem 2 - Part No SW: 8T0 919 604 HW: 8T0 919 604
Component: DU6 Basic H42 0084
Subsystem 3 - Part No SW: 8T0 919 609 HW: 8T0 919 609
Component: E0380 Bedient H08 0100
1 Fault Found:
03157 - Functionality limited due to Communications Disruption
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 13
Reset counter: 25
Mileage: 118817 km
Time Indication: 0
Date: 2015.03.24
Time: 17:32:18
Freeze Frame:
Bin. Bits: 10110111 10001010
Bin. Bits: 00000000 10001110
Bin. Bits: 00000000 00000000
[Fault 1]
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 88
Mileage: 119036 km
Date: 2015.03.28
Time: 13:33:12
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 54
Mileage: 119485 km
Time Indication: 0
Date: 2015.04.03
Time: 20:33:02
3 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 220
Mileage: 118261 km
Time Indication: 0
Date: 2015.03.15
Time: 18:45:49
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 13
Reset counter: 25
Mileage: 118817 km
Time Indication: 0
Date: 2015.03.24
Time: 17:32:18
Freeze Frame:
