Dont push pedal all the way to bottom, leave about 2 inch, if you go all the way to the floor you stand a very good chance of knackering master cylinder seals.
K so it's just a matter of pipe on undo bleed nut and pump a few time .. Is there an order how to do it .. Passenger side rear first then drivers rear passenger front then drivers front is this correct ???
With a pressure self bleed like what I have you don’t pump any pedals
Fill the bottle with new fluid and empty the reservoir of old before topping up with new and connecting bottle to reservoir.
Attach air hose to a tyre with the recommended pressure in it, then start the calliper bleed sequence while keeping an eye on the bottle level with new fluid....so not to push air into the system
