Instead of posting different threads heres 2 questions/issues im having with a 2000 a4 2.8Q
First is the gearbox is crunching when down changing to second gear at anything over 20mph.
It happens sometimes when going from 1st to 2nd also but if you are gentle and do the change slowly then it engages fine on this upshift (most of the time). On a fast run at high revs I get a slight crunch going from 2nd to 3rd also but nothing near the noise that 2nd gear is causing.
The car has done 104k miles, the clutch seems fine with no slip although the biting point is a bit high I must say. Is the syncro gone do you think??
Second is what brake upgrade is available for my model? Will RS4 discs/calipers fit my model etc etc.
