I would ask the specialists fitting it to map itMe personally. I will have my hybrid turbo fitted at my local vw audi specialists and once fitted I can't drive it anywhere.
You can drive it after fitting the hybrid. Just disconnect the electrical connector from the N75 valve.
Go to Rtech or Badger5. Both are well worth the trip
why cant you drive it?
Badger 5 or r-tech from Ipswich is around a 4-5 hour one way trip so I can understand you not wanting to do the drive mate, but as long as n75 unplugged I can't see why it would be undriveable?
not all are equipped to do anything beyond generic hard based mapping.. Installers of others "maps" vs those who write their own etcI tried Clive atthowe in norwich as they have a dyno yet they apparently can't remap my Audi A4 with hybrid. Apparently vag specialist?
So don't fit the large maf and injectors till you get to your tuner. N75 unplugged and car will be fineHybrid turbo and 550cc injectors and 3" maf will make run very bad and not advisable to drive
people very well known at doing top work to do it.
