kanecullen89
Hi all,
I currently have a problem with my PDC whereby when I put my car in reverse rather than the distance display, I get a long beep and the light flashes. This happens about 95% of the time and it works as normal about 5% of the time.
I have front and rear sensors and graphical display from the factory.
From reading on other sites, I think either a sensor or the PDC module. I have done the click test and all the sensors are clicking away and when it does randomly work I've tested all the sensors on the graphical and they're all working so I've come the the conclusion that it's probably an issue with the module.
Unfortunately I don't have vagcom to check. If anyone is willing to help in northants that would be a great help!
I currently have part number: 8K0 919 475 D
That is an 8 sensor with graphical support module.
I've seen on eBay part number: 8K0 919 475 R
This is also an 8 sensor with graphical support also but seem to be a slightly newer model.
Does anyone know if this will be plug and play or if it will need programming with vagcom?
