Engine temp problem
jamesonhurst
Hi all,
I've had a 1.8T 2001 A3 for a few years now but a few months ago I noticed a bit of a potential fault with the engine temp/thermostat.
The car takes a while to rise in engine temp especially when cold but will then get up to 90C and sit there quite happily. It never goes above this. When I turn the heater on, it blows warm on 'HI' but I wouldn't say that it was hot. With the heater on, the engine temp drops rising again to 90C when I turn it off. Most of my driving is around London but when I take it out on the motorway, after a while with the heater off, the engine temp starts to fall.
I've spoken to my mechanic (he's an Alfa specialist and can be a bit of a lazy sod) who suggested it might be the thermostat but said as long as it isn't overheating, it should be fine.
Also, the car idles high when first started as you'd expect but then falls after a minute or so to sit at below 1k RPM - not sure if this makes a difference.
Does this sound like a thermostat problem and if so am I ok to keep driving around on it?
sounds like a thermostat problem, you aren't doing any damage to your engine by driving around with this. You will use more fuel though, and personally I wouldn't "flog" the car whilst it isn't at 90 degrees (operating temp)
Thanks. To be honest it doesn't get thrashed that often as most driving is in London traffic but obviously when I'm on the motorway etc. doing higher speeds and the engine temp drops, is this going to cause issues?
Nope you'll just be getting worse mpg. Changing a thermostat is a really easy job that you could do yourself
Ok thanks. That's good to know. These cars don't have great MPG in the first place! :)
I'll have a look around for a how to guide. Presume there's a few on here.
Yupp there are a few guides here. The only hard part is getting to the bottom bolt. But if I can do it, so can you
This is normal , all the 8L's do it , it's just trying to bring your cat up to temperature for emmision purposes. :)
ive got the same prob with my s3, keeps coming up with temp sensor fault on the diagnostics tho, so will be changing that as see how it goes
27
345
540
19
