Hi I've just taken out my instrument cluster to adjust the temp and fuel gauges as they were offset. When I remove the cluster i noticed that it had amk 69k written on it. Strange as mine is a apy engine not amk.
So this would explain my epc light coming on intermittently. vag com saying ecu/wiring problem!
If the cluster and ecu are from a amk is it possible to code out the vvt as the ecu can't see the vvt. bringing up a fault.
Thanks in advance Ben.
