Psycho29
- Joined
- Dec 22, 2014
- Messages
- 1
- Reaction score
- 0
- Points
- 1
Hello Guys!
I'm looking for some help/hints on "how to" on some VAGCOM coding after installing Xenon LED Headlights, control unit is 24 bits.
I activated coming home/leaving home, but it didn't work. I can see in the FIS I can select the amount of seconds to have it working, but, still, not working.
LED's are working fine, but I want to know if maybe I need to change the light selector.
This is what I have now:
Behavior of LED's now is:
0: position LED full intensity of DRL lights ok, no rear illumination on instrument panel
Position: Led DRL low intensity, no Xenons on, rear illumination on instrument panel OK
Lights on: All on ok.
DRL I Position: DRL on
DRL 0 Position: DRL off
I think Scandinavian mode is on, as otherwise the DRL LED's didn't work if not.
Also, If I wanted to install Auto lights, what do I need to do this? New switch? Special light sensor?
I hope this makes sense to someone, if you need any kind of extra info, please ask.
Thank you in advance!!!!
