A3 oil consumption query
RS3dan
Warwickshire
Hey guys,
I have an A3 1.6 2007 (not fsi).
It does seem to use a bit of oil, nothing drastic but it does need topping up occasionally - is this normal anyway?
Moving on, there is the tell tale sign of gunk in the oil cap (consistently for some time to be fair), however it has never used a drop of coolant in it's life, I've had it 18 months ~14,000 miles. The underside is clean, no leaks anywhere that I can see but still the consumption and more alarmingly - the gunk!
Anyone have any ideas what this could be/be warning me of?
Thanks in advance!
Dan
1L per 1500 miles is normal apparently
Reactions: RS3dan
If you're not using coolant I would say it's possibly condensation !? Do you make frequent short trips ?
Not most of the time but in fairness recently I've been worked from home more frequently so it hasn't moved far! Sounds like that's probably the cause I didn't realise that could cause the gunking!
Yes, and the recent drop in temperature won't help. Just keep an eye on your coolant level and check no mayo on dipstick.
Reactions: RS3dan
45
12
10K
993
