as i'm pretty much there and ordered all the parts on my list i thought i'd post an update of my mods...
in other forums i have continually updated the first post each time a new mod has been added to my car so it keeps all the info in one spot and reduces the need for repeat posts. for some reason there is no edit on this forum so i won't be able to update this list as i go...
Engine:
2.0 TFSI Performance Turbocharger TTE420+ - not fitted
Tarmac Engineering SpecTune Upgrade Package (Inc Tune for WMI) – not fitted
Blue Flame Audi S3 Quattro 2.0 TFSi (Full 76mm System) 100 Cell Hi-Flow Cat
Evolution Motorsport 2.0T FSI V-Flow Intake
SPULEN Intake Manifold Runner Flap Delete Kit (SE-001) – not fitted
HPA Motorsports HPFP High Pressure Fuel Pump (HVA-270)
ECS Fuel Pump Cam Follower Replacement Kit (06D109309CKT)
Airtec Intercooler Upgrade for VAG 2.0 Petrol TFSI Including Black Hoses
BSH FSI Integrated Throttle Pipe Including Black Hoses(30306054)
Neuspeed HI-FLO K04 Turbo Discharge Including Black Hoses (48.02.69)
GFP DV+ Diverter Valve (T9351)
Torque Solution Billet Engine and Transmission Mount - 2.0T (TS-VW-012) – not fitted
SPULEN Engineering Dog Bone Engine Mount (SE-70116) – not fitted
SPULEN Dog Bone Engine Mount Insert Kit - Street (SE-70117)
Forge Motorsport Catch Can and PSV Delete with Boost Tap (FMMK5CTC)
OEM Audi TTRS Engine Cover (06F 103 925J)
OEM Audi Engine Cover Fitting Bolts (2x WHT000731A & 1x 06E103164E)
OEM Audi TTRS Low Pressure Fuel Pump (8J0919051E)
OEM Audi TTRS Fuel Pump Controller (8E0906071A)
OEM Audi G410 Low Pressure Fuel Pressure Sensor (06E906051K)
OEM Audi Fuel Filter (1K0201051K)
Tarmac Engineering 2.0 FSI High Pressure Rail Valve (155 Bar) – not fitted
Tarmac Engineering Water/Meth Throttle Body Spacer – not fitted
AEM V2 1-Gallon Water/Methanol Injection Kit with Internal MAP Sensor (30-3300) – not fitted
AEM Water/Methanol Injection Filter (30-3003) – not fitted
MAC 3 Port Boost Control Solenoid (35A-AAA-DDBA-1BA) – not fitted
Devils Own Water/Methanol Injection dual Nozzle Upgrade (2500) - not fitted
Devils Own Water/Methanol Injection Self Filtering Tank Tap (3019) - not fitted
Devils Own Water/Methanol Injection Check Valve (3031) – not fitted
Forge Expansion Bottle Cap and Oil Filler Cap (FMCAPS2-BLK)
Forge Silicone Carbon Canister Black Hose Kit (FMCCHMK5)
Forge Silicone Coolant Black Hose Kit (FMKC010)
Forge DV to Intake return Black Hose (FMRLH - 2L)
SPULEN 2.0T FSI Silicone Breather Black Hose (SE-022BLK)
SPULEN Brake Booster Black Hose Kit (SE-041)
ECS Billet Aluminium Oil Filter Housing – Silver Anodised (ES#2723776)
ECS Magnetic Sump Plug With 10 Copper Washers (ES#2804343)
PSI Tuning Aluminium Dipstick - 2.0TFSI (14100)
Transmission:
South Bend Stage 3 Daily Clutch and Flywheel Kit (KFSIF-SS-O)– not fitted
USP Stainless Steel Clutch Line - Audi/VW 6spd for RHD Vehicles (USP-004-78) – not fitted
Fluidampr Engine Damper 2.0TFSI (551211) – not fitted
Forge Adjustable Quick Shifter for VAG 6 Speed Models (FMVWQS)
Forge VAG 6 Speed Side Quick Shift (FMVWSQS)
42 Draft Designs VW Shifter Bushing Set (42-455-007)
Verdict Motorsports Shift Bracket Bushings (VMS100)
Suspension:
Haldex Performance Upgrade Gen 4 - 0BR Couplings Audi S3
Haldex Wireless Remote Control - Suits Gen 2 and Gen 4
35mm H&R Lowering Springs (29227-1)
Whiteline Front Sway bar - 24mm X heavy duty blade adjustable (BWF20XZ)– not fitted
Whiteline Rear Sway bar - 24mm X heavy duty blade adjustable (BWR21XZ)
Whiteline Control Arm - Lower Inner Rear Bushing - Anti-Lift/Caster Correction (KCA316)
SuperPro Roll Centre Adjusting Ball Joint (TRC0003)
Brakes:
OEM Audi TTRS Front Brake Callipers (8J0615107A and 8J0615108A)
OEM Audi TTRS Front Brake Discs (8J0615301F)
OEM Audi TTRS Front Brake Pads (8J0698151K)
RDA Dimpled and Slotted Rear Brake Discs (RDA7384D) – not fitted
Hawk Performance Ceramic Rear Brake Pad Set (HB544Z.628 )
034 Motorsport Stainless Steel Braided Brake Lines for Audi TTRS (034-303-0011) – rear not fitted
ATE Super Blue Racing Brake Fluid
Wheels:
Oettinger RE's 19x8.5 et50 5x112 Bolt Pattern
Borbet Hub Centric Rings (57.1mm to 68.00mm)
Goodyear Eagle F1 Asymmetric 235 35 19
Interior:
P3 Cars Integrated Vent Digital Gauge Audi 8P A3 (p3-vent-gauge-a3-tt-er)
P3 Cars Integrated Vent Digital Gauge Analogue boost sensor (P3BST100)
Dual OBD Port Connector (for P3 Gauge)
ECS Interior LED Lighting Kit (PL3642BA9KT1)
Bose Illuminated Speaker Grilles (CarStyle4you) – not fitted
S3 Glove Box Illuminated Handle (CarStyle4you) – not fitted
S3 Illuminated Dashboard Switches for WMI On/Off (CarStyle4you)
Audi Rings Illuminated Dashboard Status Indicator for WMI (CarStyle4you)
iPod Interface Alpine KCE-425i (IMA425I) – not fitted
ViseeO Tune2air WMA1000 - Wireless Bluetooth Music Interface Adapter – not fitted
Kufatec IMA Multimedia Adapter "Plus" (35538 ) – not fitted
Kufatec IMA - Harness - Audi RNS-E - "Basic"/"Basic-Plus" (35542) – not fitted
Kufatec IMA Control Wire - Stereo Jack 3.5 - Version 2 (35552) – not fitted
Kufatec Adapter - additional video Integration (35570) – not fitted
Kufatec IMA - Harness - Rear View Camera Auto Switch - Audi RNS-E (35676) – not fitted
Kufatec Complete set Rearview Camera Low Audi 8PA (39878)
Kufatec AMI Glove Box Storage for iPhone (37154)OEM SDS “Speech Dialogue System” UpgradeOEM Audi Ash Tray Delete (8P0863301A4P)OEM Audi Business Card Holder (8P0941561J)
OEM Universal Mobile Telephone Holder (4G0 051 435C) – not fitted
OEM Universal Mobile Telephone Cable for iPhone 6 (8V0 051 435E) – not fitted
OEM Microphone - BOSE Volume Fix (8E0 862 373A)
OEM Audi Antenna Fix (000098652A / 000098692 / 8P4035225B / 8P4035225 / 1C0973119B / 000979009)
OEM Audi Push Button Start (8E0863284E5PR / 8E0905217 / 8L0971883 / 000979009)
OEM Audi Under Seat Storage Drawer (8P08815814PK)
OEM Audi Cargo Net (8E5861869)
OEM Audi Rear Power Socket (
8E0919309 /
7L6919341F)
Rear Cargo Boot Floor Rubber Liner
Exterior:
OEM Audi Black Edition Front Grille (8P0 853 651QVMZ)
OEM Audi Black Edition Driving Light Grilles (8P0807681PZDE / 8P0807682GZDE)
OEM Audi Black Edition B Pillar Covers (8P3853289DY9B / 8P3853290DY9B) – not fitted
OEM Audi Black Edition B Pillar Cover Rivet Fixings (N0161857) – not fitted
OEM Audi Front Number Plate Delete (8p0807287H) – not fittedOEM Audi MY11 Rear Light Clusters – (8P3945095C / 8P3945096C) – not fittedLED Front Driving Lights
LED Rear Number Plate LightsFront and Back Gloss Black Audi Rings
Front and Back Gloss Black S3 BadgesLaminex Smoked Protectors for Front Main Beam and Driving Lights – not fitted
Gecleant Glass Rear Wiper Delete Plug – not fitted
Secure a Plate Rear Number Plate Holder - 372mm x 100mm (1053)
Front Bonnet Lip Car Bra
ECS Jack Adaptor Pad Kit (ECS10724KT)
