Jumped im my car today just to move around the drive all was well car was beautiful...
Then this evening came took it out all gears are smooth fine apart from reverse ...
It seems i can push the gear stick into reverse gowever it is much tighter than normal and it feels like it wont go in easy, as above the other gears are smooth
In Reverse engine running......
Once it is nearly it the reverse light comes on and when up to the bite the engine is trying against something but the car does not move forward or backwards and also if the hand break is of and clutch to the floor and the gear is in reverse the car wont roll up or down hill....
Kind of like when you are parked with the engine off and in gear and handbrake off and the clutch up ie. The gears are stopping the car from rolling
Ill have a look later again anyone had issues like this before ???
