Fan always on....HELP!!!!!!!!!!
frazgsi
Just bought a 1999 2.8 quattro and it seems the Rad fan is always on. This is very annoying because it sounds terrible when on all the time. Sounds like a bus.
Anyone have any ideas whats causing it . The car does not run hot, it runs at normal temp
The radiator fan , the main one that has the belt on it
Its a mechanical fan, driven by the belt, and runs all the time.
It has a viscous coupling, which should allow it to run at a low speed, the coupling might have siezed up and needs replaced?
yeah the viscous fan does not seem to be spinning slowly at idles , its going at the speed of the engine if you know what i mean. More i rev it the faster it goes and then the car starts to sound like a bus. please tell me these audis are not meant to be like this all the time. If so im selling it on lol
Ok thanks for clearing that up, I was starting to think that this audi was just meant to sound like a plane lol. It reminded me of the old cars with fans that didnt not have a coupling on them. The roar you used to get from them.
Ive been told swapping the vicous is a nightmare- front off, radiator moved out of way etc. This is something I cannot afford. Do you know if you can just remove the actual fan itself (held onto the coupling by 3-4 small bolts i think) and leave the coupling in place? Im willing to do this over the winter as the outside temps arent going to be too high so im sure I could do away with the fan for now as i wont need it too much
yep the fan is held on with 4 small allen head cap screws.
I'm not sure if you can reach them without at least putting the front end into service position though.
I guess you can give it a try!
Worst case you might have to break the plastic blades off to make enough room to get into the bolts.
If your car has AC, then it has a small electric fan as well, and its likely the electric fan on its own (if its working) will be enough to keep the engine cool, even in the summer.
15
938
745
14
988
9
964
